[Mapserver-users] HTML Legends as lists
Liz Godwin godwinl at agr.gc.ca
Fri Apr 2 12:58:15 PST 2004
Stephen,
That's nice and all, and looks like I want it, but from a first glance,
doesn't look very dynamic based on the map object.  I don't want to have
to manually make a legend.  It should be built from my mapfile.  I
didn't read the article in great depth, so if I missed out on this very
thing, I'm sorry.
Liz
>>> "Stephen Clark" <stephen.clark at focus.ca> 04/02/04 04:52PM >>>
Liz,
this may not be exactly what you want but if you want a tree to display
the
layers that is collapsible have a look at:
http://www.microsoft.com/mind/0799/htmltree/htmltree.asp
Stephen
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, April 02, 2004 12:16 PM
Subject: [Mapserver-users] HTML Legends as lists
> Hello all!
> I've been looking into making a collapsable legend.
> I have groups of layers, each of which have detailed class
> information.
> Now.. I can make an HTML legend work just fine.  It's the collapsing
> that's tricky.
> Currently the HTML legend works that only the code between the
> repeating sections is used, and only certain tags are available
within
> repeating sections.  These two things are preventing me from making
this
> an easy solution.
> I'd like to be able to create a heirachical list such that my group
> knows that it's children are it's layers with the same group, and
the
> layers know which classes are their own.  The way to do this would be
to
> add <ul> tags around my layers and classes.  BUT I can't.
> An alternative (but to me merely a temp. workaround) to this would
be
> to give an identifier to each layer and class that of it's parent so
> that it could be found using some javascript, but alas, my group
info
> isn't available to my layer in the HTML template file.
> Oh Mapserver Gurus...please tell me this would be something simple
to
> implement.  I think a lot of other people would be interested in
this.
> Lists are quickly becomming a popular display method in web pages
> instead of tables.
> Cheers,
> Liz Godwin
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
