[Mapserver-users] MS wont generate maps!
Ed McNierney
ed at topozone.com
Sun Apr 4 22:14:15 EDT 2004
Tom -
On the new machine, does the \Inetpub\wwwroot\tmp directory exist, and
does the anonymous Web user IUSR_<machinename> account have *write*
access to it? Check your IIS configuration for both machines.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Thomas Bartlett [mailto:tbartlett at dddd.com.au]
Sent: Sunday, April 04, 2004 9:39 PM
To: Mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] MS wont generate maps!
Hi All,
Can anyone please help I'm pulling my hair out here !!!
I have been developing a Mapserver Application on an XP machine... And
everything has been going great, BUT I am trying to migrate across to
a Windows 2000 Advanced Server machine !
Both machines are running IIS 5.0
I have set everything up in the same directories... But no matter what I
do I cant get MapServer to generate images? I have put a LOG reference
in the .map file but the file is not created, or if I create it nothing
is added to it!
MapServer is working.... Because when I have errors in my map file or in
the url... Errors are returned. When I submit a properly formatted
url, the template document is return with broken links for the images
(ref, legend,scalebar and img). These link are where the images should
be.... But no images are created !!
I know I'm missing something simple... I just don't know what !!
I have tried setting IMAGEPATH and IMAGEURL in the .map file or setting
MAP_WEB_IMAGEURL and MAP_WEB_IMAGEPATH nothing seems to works
PLEASE HELP !!
Many Thanks
Tom Bartlett
# Start of map file
MAP
NAME UXO
STATUS ON
SIZE 600 600
EXTENT 140 -26.50 154 -40
UNITS DD
SHAPEPATH "C:\MapServer_Data\"
IMAGECOLOR 255 255 255
TEMPLATEPATTERN "UXO_Basic"
IMAGETYPE PNG
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER templates/header.html
TEMPLATE "set in /index.html"
FOOTER templates/footer.html
MINSCALE 1000
MAXSCALE 10000000
IMAGEPATH "set in /index.html"
IMAGEURL "set in /index.html"
LOG UXO_Mapserver
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is a UMN MapServer application for Itasca
County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://localhost/UXO/index.html"
WMS_SRS "EPSG:26915"
END
END
# Start of reference map
REFERENCE
IMAGE graphics/aust_ref.png
EXTENT 111.33 -7.87 156.12 -46.84
SIZE 150 133
STATUS ON
MINBOXSIZE 5
#MAXBOXSIZE 120
OUTLINECOLOR 255 255 255
MARKERSIZE 9
MARKER 'star'
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE TINY
END
STYLE 1
SIZE 400 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 5
TRANSPARENT TRUE
STATUS ON
END
QUERYMAP
SIZE 250 250
STYLE HILITE
COLOR 255 255 0
STATUS ON
END
# Start of layer definitions
LAYER
NAME GMA_BUILTUPA
TYPE POLYGON
STATUS OFF
DATA GMA_1m/QLD/builtupa_qld
MAXSCALE 10000000
MINSCALE 250000
CLASS
NAME 'Built-up Area'
STYLE
COLOR 255 190 190
END
END
TOLERANCE 3
END # GMA_BUILTUPA
END # Map File
<html>
<head>
<title>MapServer Itasca Application</title>
</head>
<body bgcolor="#FFFFFF">
<center><h2>MapServer Itasca Application</h2></center>
<p><hr><p>
This demonstration application will take you through various levels
of complexity. Starting with a basic application that
allows a user to pan/zoom and change layers we add:
<ul>
<li> dynamically configured scalebars
<li> javascript-based panning
<li> query results to a frame
<li> and finally, a DHTML rubber-band zoom/query capabilty
</ul>
The base data is the old-reliable Itasca dataset that we know and
love...
<!-- EDIT THE FORM ACTION -->
<form name="demo" method="GET" action="/mapserv40/mapserv.exe">
<input type="hidden" name="layer" value="GMA_BUILTUPA">
<input type="hidden" name="zoomsize" value=2>
<!-- EDIT THESE HIDDEN VARIABLES -->
<input type="hidden" name="map"
value="C:\Inetpub\wwwroot\UXO\UXO_custom.map">
<input type="hidden" name="program"
value="/mapserv40/mapserv.exe">
<input type="hidden" name="root" value="/UXO/">
<input type="hidden" name="map_web_imagepath"
value="C:\Inetpub\wwwroot\tmp\">
<input type="hidden" name="map_web_imageurl" value="\UXO\tmp\">
<input type="hidden" name="map_web_template"
value="UXO_Basic.html">
<input type="submit" value="Initialize"></center>
</form>
<p><hr><p>
</body>
</html>
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
