[Mapserver-users] Mapserver 4.1 compile using VC 6
Swaminathan, Gayathri
gayathri at ou.edu
Mon Apr 5 12:49:38 EDT 2004
Hi List:
I thought I will post my petty hurdles...to the list when compiling
mapserver 4.1....(incase someone else comes across similar problems when
compiling)
Used,
GD - 2.0.22- http://www.boutell.com/gd/manual2.0.22.html#buildgd
Zlib- went well (use included makefile)
GDAL1.2 - went smooth (use included makefile)
Regex-0.12 - (use included makefile)
ECW_SDK from http://ermapper.com
curl and libcurl 7.11.1 - Use included workspace in source
Freetype2.1.7 - Use included workspace in source
Lib png 1.2.5 -smooth build - (use included makefile)
Proj 4.4.7-smooth build - (use included makefile)
Modify makefile to compile maptime.obj
Oh! And make sure you have same OPTFLAGS defined when compiling
mapserver and gdal to avoid mismatched set of compile/build options
(http://remotesensing.org/pipermail/gdal-dev/2003-December/001582.html).
HTH,
Gayathri
