[Mapserver-users] I'm getting a little frustrated...
Paul VanDyke
pvandyke at kib.co.kodiak.ak.us
Mon Apr 5 15:05:03 EDT 2004
Eureka!!! Success at last!! WOOT!!!
Ok, using the LISTGEO tool, I was able to find the correct extents to MY
(not the tutorial's) tif image. I plugged those in on a test map and
can now see a working raster image in mapserver. Now I have proff that
it works on my system in my environment. THANK YOU ED!!!
Now, how do I display my raster and my shape files together on the same
page? When I look at the extents, they don't overlap. However, when I
add them as two layers in ArcMap they mesh perfectly. I do have a .wld
file for the tif. Do I need to create/adjust my projections? All the
files are NAD_27. Again, this is a learning process for me, so I
appreciate all the help that everyone is giving me.
Here is the new .map file that I'm working with:
MAP
NAME map7
IMAGETYPE PNG
EXTENT 517415 6368214 542392 6403304
SIZE 800 400
SHAPEPATH "c:/program files/apache group/apache2/htdocs/data"
IMAGECOLOR 255 255 255
DEBUG ON
WEB
TEMPLATE 'map6.html'
IMAGEPATH '/data/tmp/'
IMAGEURL '/tmp/'
LOG 'c:\mapserver.log'
END
# Start of LAYER DEFINITIONS -----------------------------
LAYER # water
NAME water
DATA kib_boundary
STATUS DEFAULT
TYPE POLYGON
CLASS
STYLE
COLOR 115 207 255
OUTLINECOLOR 32 32 32
END
END
END
LAYER # coast
NAME coast
DATA kib_coast
STATUS DEFAULT
TYPE POLYGON
CLASS
STYLE
COLOR 0 216 56
END
END
END
LAYER # MODIS raster layer begins here
NAME test123
DATA raster/kodiakc2.tif
STATUS DEFAULT
TYPE RASTER
# PROCESSING "BANDS=1"
# OFFSITE 71 74 65
END # MODIS raster layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Here is the output from the LISTGEO on the kodiakc2.tif file:
C:\Program Files\Apache Group\Apache2\htdocs\data\raster>listgeo
kodiakc2.tif
Geotiff_Information:
Version: 1
Key_Revision: 0.2
Tagged_Information:
ModelTiepointTag (2,3):
0 0 0
517415.363 6403304.71 0
ModelPixelScaleTag (1,3):
6.437376 6.437376 0
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeProjected
GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
ProjectedCSTypeGeoKey (Short,1): PCS_NAD27_UTM_zone_5N
PCSCitationGeoKey (Ascii,24): "UTM Zone 5 N with NAD27"
End_Of_Keys.
End_Of_Geotiff.
PCS = 26705 (name unknown)
Projection = 16005 ()
Projection Method: CT_TransverseMercator
ProjNatOriginLatGeoKey: 0.000000 ( 0d 0' 0.00"N)
ProjNatOriginLongGeoKey: -153.000000 (153d 0' 0.00"W)
ProjScaleAtNatOriginGeoKey: 0.999600
ProjFalseEastingGeoKey: 500000.000000 m
ProjFalseNorthingGeoKey: 0.000000 m
GCS: 4267/NAD27
Datum: 6267/North American Datum 1927
Ellipsoid: 7008/Clarke 1866 (6378206.40,6356583.80)
Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
Corner Coordinates:
Upper Left ( 517415.363,6403304.706)
Lower Left ( 517415.363,6368214.569)
Upper Right ( 542392.381,6403304.706)
Lower Right ( 542392.381,6368214.569)
Center ( 529903.872,6385759.638)
Here's the kodiakc2.wld file
21.098407687615669
0.283828823820080900
0.308025501864488020
-21.117268418850411
752488.58435255091
1380675.7577753554
Thanks,
Paul
