[Mapserver-users] WMS requests.
Swaminathan, Gayathri
gayathri at ou.edu
Mon Apr 5 17:21:52 EDT 2004
Bob,
I would rather do the following to get the interoperability working with
ArcExplorer...(Am gonna list all the steps for your quick reference :)
1) Get the Interoperability extension for ArcExplorer -Java Edition
version 4.0.1 I think.
2) Install that.
3) Get Capabilities using,
http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?map=<mappath>&VERSIO
N=1.1.1&REQUEST=Getcapabilities
This should pop you a XML file (does not have .xml extension but, that's
ok)- Save that to disk
4) Do this at the beginning of the document.
<?php
header("Content-type:application/vnd.ogc.gml");
<WMT_MS_Capabilities version="1.1.1" updatesequence="0">=====> (This
line is already in your capabilities file you downloaded in step 3, you
will have
to change the version from 1.1.0 to 1.1.1, that is all)
5) Save file as <something>.php under your local intranet site for
example, could be
http://dragonslayer.ci.stpaul.mn.us/pws.php
6) Open up ArcExplorer->Interoperability(Menu)->Connect to WMS, type in
the URL of the .php file, For example,
Hit OK!
And you should get the layers.
HTH. Let me know if you are running into issues.
Gayathri
> -----Original Message-----
> From: Bob Basques [mailto:bob.basques at ci.stpaul.mn.us]
> Sent: Monday, April 05, 2004 4:14 PM
> To: Swaminathan, Gayathri
> Subject: Re: [Mapserver-users] WMS requests.
> Swaminathan, Gayathri wrote:
> >No problem,
> >On the ArcExplorer...use the hints from here...
> >http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WMSMapserverArcExplorer
> >They are helpful
> I just read in detail, the Message console is a slick troubleshooter,
> Any idea about what this output might mean related to
> connecting to my
> service?
> GetCapabilities Request :
> http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?SERVICENAM
> E=pw&VERSION=1.1.1&WMTVER=1.1.1&SERVICE=WMS&REQUEST=capabilities
> ###### Start to WMS getCapabilities in GetWMSService class
> version=null
> ************** realVersion is = none
> ************** Version is = null
> This version is not supported
> ******** Exception for WMS:null
> java.lang.NullPointerException
> at com.esri.ogc.client.WMSServer.refresh(WMSServer.java:236)
> at com.esri.ogc.client.WMSServer.<init>(WMSServer.java:67)
> at com.esri.ogc.client.WMSServer.getLayerSource(WMSServer.java:48)
> at com.esri.ogc.client.WMSUtil.AddWMSLayer(WMSUtil.java:306)
> at
> com.esri.ogc.viewer.extensions.WMSConnectionDialog.jButton_OK_
> actionPerformed(WMSConnectionDialog.java:164)
> at
> com.esri.ogc.viewer.extensions.WMSConnectionDialog$1.actionPer
> formed(WMSConnectionDialog.java:74)
> at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
> at
> javax.swing.AbstractButton$ForwardActionEvents.actionPerformed
> (Unknown
> Source)
> at
> javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
> at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
> at
> javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown
> Source)
> at java.awt.Component.processMouseEvent(Unknown Source)
> at java.awt.Component.processEvent(Unknown Source)
> at java.awt.Container.processEvent(Unknown Source)
> at java.awt.Component.dispatchEventImpl(Unknown Source)
> at java.awt.Container.dispatchEventImpl(Unknown Source)
> at java.awt.Component.dispatchEvent(Unknown Source)
> at
> java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
> at
> java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
> at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
> at java.awt.Window.dispatchEventImpl(Unknown Source)
> at java.awt.EventQueue.dispatchEvent(Unknown Source)
> at
> java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
> at
> java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
> at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
> at java.awt.EventDispatchThread.run(Unknown Source)
> >Gayathri
> >>Sent: Monday, April 05, 2004 3:45 PM
> >>>Mea Culpa!
> >>>Should be Layers=L5.
> >>>That should work.
> >>Geez, I tried every combination but that one! I eve through
> >>the "s" on
> >>the end a couple of times. It Worked!!
> >>Now to figure out the interoperability extension for ArcExplorer.
> >>Thanks (A lot!!) for the help here.
> >>bobb
