[Mapserver-users] which OGC specs and versions compies the actual umn mapserver 4.0.1 (4.1)
Arnulf Christl arnulf.christl at ccgis.de
Tue Apr 6 07:59:32 PDT 2004
Sebastian Bölling wrote:
>Hi,
>which OGC specifications (WMS, WFS, GML) and versions complies the actual UMN MapServer 4.0.1 (and 4.1 in the future)? At the OGC website (http://www.opengis.org/resources/?page=products) there is only some old information about the MapServer 3.5 which is compatible to OGC WMS 1.1.0.
a slightly longer answer comes here: We are using UMN MapServer as WMS
1.1.0, 1.1.0 and 1.1.1 and have also tested WFS 1.0.0. with an
underlying PostgreSQL/PostGIS database. Runs smoothly. Most of the SLD
support has recently been added and documented here:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?SLDMapServer
But: You got to be careful with the term "compatible" in the OGC context
as I had to learn the hard way last year... The correct word is
"implementing", they are sort of  a little fussy about that.
Anyway - UMN MapServer is still not implementing WMS correctly as it
always returns images with "square" pixels. If you use UMN MapServer as
the only service don't bother about it. If you have to combine it with
other WMS it might be problematic.
Its a little tricky to get the gist of this problem. Whenever you
request an image which has an inconsitent aspect ratio of pixels and
coordinates, UMN MapServer will cheat by adding as much map as is needed
to fill up the difference until it can return "square" pixels. The OGC
spec. specifies that instead the image should be stretched. If you
overlay the MS' result with another WMS which does return (WMS
compliant) warped images you will see the difference, whenever the
client works with warped start-up parameters. In the center of the map
the overlay looks good, the further you get to the border of the map the
larger will be the delta.
Best regards,
Arnulf.
>Best regards,
>Sebastian Boelling
>_____________________________________________________________________
>Der WEB.DE Virenschutz schuetzt Ihr Postfach vor dem Wurm Netsky.A-P!
>Kostenfrei fuer alle FreeMail Nutzer. http://f.web.de/?mc=021157
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
CCGIS Christl & Stamm GbR
http://www.ccgis.de
http://www.mapbender.org
Service: +49 (0)228 90826 0
Direct:  +49 (0)228 90826 23
Fax:     +49 (0)228 90826 11
Siemensstraße 8
53121 Bonn
GERMANY
More information about the MapServer-users mailing list
