[Mapserver-users] Accessing PostGIS layers via OGR in MapServer
Mike Leahy
mgleahy at fes.uwaterloo.ca
Tue Apr 6 16:18:16 EDT 2004
I was sure of that - I played around with orginfo and ogr2ogr exporting
tables to shapefiles and such before I got to trying it in MapServer. Could
it be my setup? I.e., does the mapserv.exe in my Inetpub/Scripts folder for
IIS actually use the OGR I compiled in Cygwin? I think maybe not...
Here's what ogrinfo --formats returns:
Loaded OGR Format Drivers:
-> "ESRI Shapefile" (read/write)
-> "UK .NTF" (readonly)
-> "SDTS" (readonly)
-> "TIGER" (read/write)
-> "S57" (read/write)
-> "MapInfo File" (read/write)
-> "DGN" (read/write)
-> "VRT" (readonly)
-> "AVCBin" (readonly)
-> "REC" (readonly)
-> "Memory" (read/write)
-> "GML" (read/write)
-> "PostgreSQL" (read/write)
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: April 6, 2004 4:02 PM
To: Mike Leahy
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Accessing PostGIS layers via OGR in MapServer
Mike Leahy wrote:
> Hello list,
> I'm trying to see if I can access PostGIS layers via the OGR input type in
> the MapServer 4.1 development version. The warning message below is about
> as far as I can get:
> Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR
connection
> `PG:dbname=educal user=Administrador host=localhost'. File not found or
> unsupported format
> I've tried several formats of connection strings in addition to the one in
> the example above:
> PG:'dbname=educal user=Administrador host=localhost'
> PG:dbname=educal;user=Administrador;host=localhost
> PG:dbname=educal
> So far, none have worked. I've got PostGIS 0.8 installed as well as GDAL
in
> CygWin, with MapServer running as CGI in IIS on WinXP. I can run OGR
> components from CygWin okay (e.g., ogr2ogr), but I just don't seem to have
> any luck with it in MapServer yet. I'm hoping it's just a problem with my
> connection string. When I connect using PostGIS directly, the connection
> string "user=Administrador dbname=educal host=localhost" works fine.
Mike,
How confident are you that your OGR build includes PostGIS support? Try
"ogrinfo --formats" and see if there is a "PostgreSQL" driver listed.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
