[Mapserver-users] Compiling PHP_MapScript.dl...
Mike Leahy mgleahy at fes.uwaterloo.ca
Wed Apr 7 05:55:33 PDT 2004
Okay list...here's my progress since yesterday:
I compiled MapServer 4.0.1 with the following config:
./configure \
--with-jpeg \
--with-gd=/usr \
--with-freetype=/usr \
--with-zlib=/usr \
--with-png=/usr \
--with-pdf=/usr \
--with-tiff=/usr \
--without-eppl \
--with-proj=/usr \
--with-ogr=/usr/bin/gdal-config \
--with-postgis=/usr/bin/pg_config \
--with-wfs \
--with-wmsclient \
--with-wfsclient \
--with-curl-config=/usr/bin/curl-config \
--disable-ignore-missing-data \
--with-php=/usr/src/php-4.3.5
I'm successful up to this point.  :)
Now I'm stuck with several *.o files in place of the DLL that I actually need
for PHP_MapScript.  So...I went through a lengthy goose chase, and eventually
compiled all the *.lib versions of the library components I originally built
in Cygwin.  I finally got everything (I think) compiled that was needed to
create the PHP_MapScript.dll using the makefile.vc.  I thought I finally had
it, then got the following from running nmake:
D:\Downloads\Programs\Progra~1\MapServer\VCProject\postgresql-7.4.2
\src/interfaces/libpq/libpqdll.lib      .
./../libmap.a  D:\Downloads\Programs\Progra~1\MapServer\VCProject\php-4.3.5-
Win32\lib\php4ts.lib
Microsoft (R) Incremental Linker Version 6.00.8447
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _atoi already defined in
      Etc....
MSVCRT.lib(MSVCRT.dll) : error LNK2005: __strdup already defined in LIBC.lib
(strdup.obj)
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _atoi already defined in LIBC.lib
(atox.obj); second definition ignored
      Etc....
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: __strdup already defined in LIBC.lib
(strdup.obj); second definition ignored
   Creating library php_mapscript.lib and object php_mapscript.exp
LINK : warning LNK4098: defaultlib "MSVCRT" conflicts with use of other libs;
use /NODEFAULTLIB:library
php_mapscript.o : error LNK2001: unresolved external symbol _sapi_module
libmap.a(mapparser.o) : error LNK2001: unresolved external symbol __alloca
      Etc....
libmap.a(mappostgis.o) : error LNK2001: unresolved external symbol _rindex
libmap.a(maphttp.o) : error LNK2001: unresolved external symbol _select
php_mapscript.dll : fatal error LNK1120: 59 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
I'm guessing this is because I compiled MapServer in Cygwin and now I'm trying
to get a Win-compatible DLL from the same package.  If I'm wrong, can anyone
suggest what I need to fix next?  If so, I'm now looking at figuring out how
to compile MapServer using MSVC.  So far that's looking a bit scary.  I got
pretty far with respect to the libs needed for the MapScript DLL, but I'm
already running into problems getting all the requirements setup for
MapServer, particularly regarding PHP and Regex.
Any suggestions?
Thanks,
Mike
This mail sent through www.mywaterloo.ca
More information about the MapServer-users mailing list
