[Mapserver-users] Mapserver - OGR - Oracle (revisited)
Bart van den Eijnden
bartvde at xs4all.nl
Wed Apr 7 14:28:17 EDT 2004
Hi Frank,
thanks for your reaction. I have submitted an enhancement bug about this
in the GDAL bugzilla (543).
With regard to the DATA statement, do you have any idea why only the
second option incorporates the BBOX in the query which is sent to Oracle?
Would the only way to use a WHERE clause (or to not select all columns of
a table) be to define a view in Oracle and use the view in the DATA
statement?
Best regards,
Bart
On Wed, 07 Apr 2004 13:10:30 -0400, Frank Warmerdam <warmerdam at pobox.com>
wrote:
> bartvde at xs4all.nl wrote:
>> Hi list,
>> on a previous post I mentioned that it appeared that the BBOX of the WMS
>> request was not used in the query sent to Oracle.
>> This was caused by the DATA statement in the MAP file. If we used a
>> select
>> statement there (like the one commented out in the example below),
>> always
>> a full table scan was performed. Using the lower "syntax" it works fine.
>> # DATA "select ORA_GEOMETRY from AdreSDO"
>> DATA AdreSDO
>> But now there is the following problem that a WMS GetCapabilities
>> request
>> takes more than one minute (also resulting in a full table scan in
>> Oracle). Is there any way to prevent this, can it be read from the
>> USER_SDO_GEOM_METADATA table or the MAP file?
> Bart,
> As I think Daniel noted in another message, you can pre-supply the extent
> (which is what I assume is taking a long time). The better solution
> would
> be for me to override the OGR OCI driver's GetExtent() logic to use the
> USER_SDO_GEOM_METADATA as you suggest. I kind of thought I had done
> that,
> but looking through the code I see the generic logic is used which
> involves
> reading the complete table.
> Feel free to submit that as an enhancement request in the GDAL/OGR
> bugzilla.
> While a great deal of work went into optimization of the OCI driver for
> loading Oracle with data, the read side was not nearly as well optimized
> since that was not the focus of the funding project.
> Best regards,
