[Mapserver-users] Projection Help
    Paul VanDyke
    pvandyke at kib.co.kodiak.ak.us
    Wed Apr  7 17:05:45 PDT 2004
Thanks for your quick reply.
The original jpeg does not have any info associated with it.  It was
just a satellite photo I found on the 'net and saved to my hard disk.
It is totally unrectified.
I've rectfied it myself by using the georeferencing toolbar in ArcMap.
It allows you to manipulate the raster image to make it fit your map.
The raster data and shapefile do meet up fine in ArcMap
Here is the output from gdalinfo:
Driver: GTiff/GeoTIFF
Size is 1833, 1141
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["NAD27",
        DATUM["North_American_Datum_1927",
            SPHEROID["Clarke 1866",6378206.4,294.9786982139006,
                AUTHORITY["EPSG","7008"]],
            AUTHORITY["EPSG","6267"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4267"]],
    UNIT["unknown",1],
    AUTHORITY["EPSG","26735"]]
Origin = (-216345.100010,1788844.874145)
Pixel Size = (839.88083200,-839.88083200)
Metadata:
  TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.9.1.2 $ $Date: 2001/12/05 00:33:12Z
  TIFFTAG_XRESOLUTION=1
  TIFFTAG_YRESOLUTION=1
  TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left  ( -216345.100, 1788844.874) (12395661d
8'42949673016.16"W,102493261d29'369367187487.67"N)
Lower Left  ( -216345.100,  830540.845) (12395661d
8'42949673016.16"W,47586485d7'171798691859.82"N)
Upper Right ( 1323156.465, 1788844.874) (75811281d
4'274877907001.22"E,102493261d29'369367187487.67"N)
Lower Right ( 1323156.465,  830540.845) (75811281d
4'274877907001.22"E,47586485d 7'171798691859.82"N)
Center      (  553405.683, 1309692.859)
(31707809d58'115964116992.53"E,75039873d18'270582939673.75"N)
Band 1 Block=1833x4 Type=Byte, ColorInterp=Red
Band 2 Block=1833x4 Type=Byte, ColorInterp=Green
Band 3 Block=1833x4 Type=Byte, ColorInterp=Blue
Thanks,
Paul
More information about the MapServer-users
