[Mapserver-users] --with-php, Mapserver 4.0.1, and Fedora
Lindsay C. Blanton
lindsay at lcblanton.com
Wed Apr 7 21:09:30 EDT 2004
No joy on the RPMS - they don't include the PHP Module.
Anyone else out there have suggestions for a good compile with PHP
support on Fedora?
Warm regards,
Lindsay
> -----Original Message-----
> From: Lindsay C. Blanton
> Sent: Wednesday, April 07, 2004 2:18 PM
> To: Paul Dugas
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] --with-php, Mapserver 4.0.1, and Fedora
> Hmmm. I might give this a shot.
> One thing I noticed is the PostGIS folks have a complete RPM
> distribution of MapServer 4.0.1 with all associated
> dependencies etc for the Fedora Core 1. It looks to be about
> 15 RPMs in total.
> http://www.postgis.com/rpms/fedora/1/i386/
> I'm going to try to install each of these in lieu of
> continuing with the compile process. I can't see anywhere on
> PostGIS's site any indication that their RPM installable
> version of MapServer 4.0.1 was compiled with PHP support,
> however I would assume that it is.
> I'll keep the list advised.
> Lindsay
> Lindsay C. Blanton
> Webmaster
> http://www.radioreference.com
> > From: Paul Dugas [mailto:Paul at DugasEnterprises.com]
> > Sent: Wednesday, April 07, 2004 1:30 PM
> > To: Lindsay C. Blanton
> > Subject: Re: [Mapserver-users] --with-php, Mapserver 4.0.1,
> and Fedora
> > Lindsay C. Blanton said:
> > > I downloaded the source RPM's for PHP, and pointed the
> > --with-php=DIR
> > > directive to the source directory where they were
> > installed, however
> > > the configure script is still complaining that config.h /
> > php_config.h
> > > is not present. I can't find these files anywhere in the latest
> > > distributions of PHP 4.3.5, nor with the Redhat Sources for php.
> > Tried it today with the same setup and got a bit farther but
> > not all the way. I installed the php-devel RPM rather than
> > the full source package and got it to configure using
> > 'configure --with-php=/usr/include/php/main'. Then I
> > manually modified the resulting Makefile in mapscript/php3/ changing
> > PHP_SRC_DIR = /usr/include/php/main
> > to
> > The build went okay but I got all kinds of errors (didn't
> > record them but could if needed) when I copied the SO into
> > the right directory, fired up apache, and hit some of the
> > examples. I'm wondering if this might be an apache 2.0 problem?
> > Paul
> > Paul A. Dugas <paul at dugasenterprises.com> phone:
> 404.932.1355
> > Dugas Enterprises, LLC fax:
> 770.516.4841
> > 1711 Indian Ridge Drive, Woodstock, GA 30189 USA
> > On-site at Georgia DOT, 404.463.2860 x158,
> paul.dugas at dot.state.ga.us
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
