[Mapserver-users] --with-php, Mapserver 4.0.1, and Fedora
Lindsay C. Blanton
lindsay at lcblanton.com
Wed Apr 7 20:11:30 PDT 2004
Daniel,
Many thanks for the detailed response.. It is greatly appreciated, as is
all your hard work on this project.
I am absolutely astounded at how great, and powerful, of an effort this
is.
Regards,
Lindsay
> -----Original Message-----
> From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
> Sent: Wednesday, April 07, 2004 9:59 PM
> To: Lindsay C. Blanton
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] --with-php, Mapserver 4.0.1, and Fedora
> Lindsay C. Blanton wrote:
> > Is there anything in the overall architecture preventing
> you guys from
> > developing this to run in the standard PHP/Apache
> configurations that
> > so many people run (as a module)?
> Yes and no.
> The good news is that the 4.1 CVS version (to be released as
> 4.2) should
> be able to run with PHP as a module in theory, but the bad
> news are that
> it's almost impossible to build that combination at the
> moment without
> tweaking the build process manually. Unfortunately PHP isn't very
> friendly to large extension modules that come with lots of
> dependencies
> such as PHP MapScript.
> The main issues are that PHP comes with its own bundled copy of regex
> and GD which are also used by MapServer, and unless you build the
> MapServer core with the exact same versions of GD and regex
> then you end
> up with symbol conflicts at runtime and odd behavior/crashes. If you
> build PHP from source then you can get it to use the system
> GD, but you
> _cannot_ force PHP to use the system regex when you build it as an
> Apache module... this is a major issue for us. Plus if you
> got the php
> and php-devel RPM then chances are that they use PHP's bundled GD and
> then you have two problems.
> I'm still pulling my hair trying to find a nice way to solve that
> problem... that's one of the main issues that I would like to resolve
> before the 4.2 release.
> Note that I don't expect the 4.2 release version to be extremely
> tested/stable under the PHP module configuration... this mode should
> still be considered experimental for the 4.2 release, and
> will hopefully
> become more stable in a later release closer to the summer.
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
More information about the MapServer-users
