[Mapserver-users] re:install help
David Fawcett
David.Fawcett at state.mn.us
Thu Apr 8 13:14:59 EDT 2004
Take a look at index.html.
Starting on line 34, there are several hidden variables. Have you set
their values to reflect your personal setup?
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> <burnsy at vividfish.co.uk> 4/8/2004 11:47:31 AM >>>
Thanks for the quick reply.
I checked the .map file
IMAGEPATH is set to c:\inetpub\wwwroot\tmp\
IMAGEURL is set to /tmp/
I cant see any files being generated into the specified folders. The
other
static examples in the tutorial work (examples 1-1 to 1-5).
Thanks again
burnsy
David Fawcett wrote:
>>Is the application producing images?
>>Verify that IMAGEPATH and IMAGEURL in your Map file are correct.
>>Also, make sure that the image tag or image URL in your templates
>>matches IMAGEURL.
>>David J. Fawcett
>>>>>>>><burnsy at vividfish.co.uk> 4/8/2004 10:30:02 AM >>>
>>Hello,
>>got a copy of the win32 files installed on win2k. After installing
the
>>demo
>>application I can see the pages but the image files are displaying
>>(showing as
>>broken links), except for the ones on the rubber band box demo which
>>work
>>perfectly and display maps from the sample data.
>>Any one had this issue and know what I have done wrong?
>>Thanks
>>burnsy
>>This message was sent using IMP, the Internet Messaging Program.
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
