[Mapserver-users] querybyshape failing
Daniel Morissette
dmorissette at dmsolutions.ca
Tue Apr 13 09:10:42 EDT 2004
AARON KONING wrote:
> Hi List,
> I am having a problem with the php mapscript querybyshape method of the layerobj (and mapobj). When I create a polygon outlining the entire layer I get the 'No matching record(s) error even though I assume that the query should have found all records. Does querybyshape check for features contained/intersected/? and why is the following code failing.
Does a queryByRect() on the same layer and with the same extents return
something?
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
