[Mapserver-users] request=GetMap& error in MapServer v4.1
Rene Teniere TENIERER at gov.ns.ca
Thu Apr 15 05:28:00 PDT 2004
If we have to specify almost everything in the GetMap request, why do we
have to have it in the WMS server map file as well??
>>> "Daniel Morissette" <dmorissette at dmsolutions.ca> 2004-04-14 5:30:20
PM >>>
Ed McNierney wrote:
> I'm a little puzzled - your GetMap request is missing several
required
> parameters (SRS, BBox, Width, Height, Layers, etc.).  I'm surprised
it
> worked at all in 4.0.2.  The error message is (a little obscurely)
> complaining because you have no LAYERS at all.
Before V4.1, MapServer used to forgive all those missing parameters in
GetMap and use default values from the mapfile.
In 4.1 the checking has been made more strict on some parameters in
order to pass some of the tests in the OGC test suite, and the LAYERS
parameter is one of those parameters that we check for.  You probably
get the error on LAYERS because it's the first parameter that is
checked
for, and once it finds one error it stops and doesn't report other
missing parameters.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
