[Mapserver-users] Passing CGI variables
David Mitchell
david.mitchell at telogis.com
Fri Apr 16 00:35:24 EDT 2004
Dharani,
REQUEST_METHOD and QUERY_STRING are environment variables, not
parameters to the application. Try this instead:
C:\TEST>set "REQUEST_METHOD=GET"
C:\TEST>set "QUERY_STRING=map=c:\....."
C:\TEST>mapserv_40.exe
David
Dharani Babu wrote:
> Hi David
> Thanks . I moved all the contents of
> C:/ms4w/apache/cgi-bin/mapserv_40.exe and all the other dlls into a
> folder C:/test/ mapserv.exe . Ok . Now I passed the command paramaters
> like this
> C:\TEST>mapserv_40.exe "REQUEST_METHOD = GET"
> "QUERY_STRING=map=C%3A%2Fms4w%2Fapache%2Fhtdocs%2Fdemof%2Frock_pic.map&layer=tigerdata&zoomdir=1&zoomsize=2&progra
> m=%2Fcgi-bin%2Fmapserv_40.exe&map_web_imagepath=C%3A%2Fms4w%2Fapache%2Fhtdocs%2Ftemp_rm6%2F&map_web_imageurl=%2Ftemp_rm6%2F"
> I Got the following error .
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> I hope I am missing the syntax . I tried other combinations also still
> missing.pls tell me the syntax of it .
> with regard and thanks
> dharani
>> From: David Mitchell <david.mitchell at telogis.com>
>> To: Dharani Babu <dharanibabus at hotmail.com>
>> CC: mapserver-users at lists.gis.umn.edu
>> Subject: Re: [Mapserver-users] Passing CGI variables
>> Date: Fri, 16 Apr 2004 13:43:08 +1200
>> Dharani,
>> If you want you can call mapserv directly as you wish but you have to
>> first set the QUERY_STRING and REQUEST_METHOD environment variables to
>> trick it into thinking it is being accessed through IIS:
>> REQUEST_METHOD=GET
>> QUERY_STRING="zoomdir=1&zoomsize=2..."
>> That is all that IIS does anyway (not strictly true, IIS sets a few
>> more variables and does a bit of house-keeping, but essentially the
>> same). If your map has a template then the image will be in your temp
>> folder and the std output of mapserv.exe will be the webpage (which
>> you can throw away essentially).
>> David
>> Dharani Babu wrote:
>>> Thanks Daniel - all
>>> This helped me get a vb.net picture box based wrapper for the MS .
>>> I have a question though .
>>> As you when we post the CGI variables we are in need of posting it in
>>> the form of a html stream only--like
>>> "http://192.168.2.135/cgi-bin/mapserv_40.exe?zoomdir=1&zoomsize=2&"
>>> etc . But is there any alternative so that I can pass it with
>>> "C:/ms4w/apache/cgi-bin/mapserv_40.exe?zoomdir=1&zoomsize=2&" ?
>>> But I know very well the map server exe works with Apache or IIS .
>>> But I want to copy the map server exe and its associated dlls to a
>>> location other then the cgi-bin or scripts . Is it possible ?
>>> Is there any way we can make MS exe to get the html stream and give
>>> us the image in tmp folder WITHOUT Apache or IIS ? I am trying to
>>> get a soln by running dependency walker on ms exe and other trails
>>> with spy tools . Still not yet solved .
>>> with regards and thanks in advance
>>> dharani
>>>> From: Daniel Morissette <dmorissette at dmsolutions.ca>
>>>> Date: Sat, 10 Apr 2004 11:54:24 -0400
>>>> Dharani Babu wrote:
>>>>> 1) I am trying to pass the CGI variables to the map server exe
>>>>> without HTML submission .Thats I am trying to disassociate the
>>>>> browser based rendering .Could any of you point to the direction ?I
>>>>> have been able to pass the url thro a C# /VB.net web browser
>>>>> control . But searching for an alternative . I tried passing CGI
>>>>> variables thro command prompt but got a message that " cgi
>>>>> variables can be passed only via httpd " .
>>>> You can call the mapserv.exe at the command prompt using
>>>> mapserv.exe "QUERY_STRING=map=/path/to/yourmap.map&mode=...&..."
>>>> Daniel
>>>> Daniel Morissette dmorissette at dmsolutions.ca
>>>> DM Solutions Group http://www.dmsolutions.ca/
>>> _________________________________________________________________
>>> Contact brides & grooms FREE!
>>> http://www.shaadi.com/ptnr.php?ptnr=hmltag Only on www.shaadi.com.
>>> Register now!
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>> David Mitchell
>> Software Engineer
>> Telogis
>> NOTICE:
>> This message (including any attachments) contains CONFIDENTIAL
>> INFORMATION intended for a specific individual and purpose, and
>> is protected by law. If you are not the intended recipient,
>> you should delete this message and are hereby notified that any
>> disclosure, copying, or distribution of this message, or the
>> taking of any action based on it, is strictly prohibited.
> Strike the right balance! News, gossip n fundas!
> http://www.msn.co.in/women/ Get it all at MSN Women!
David Mitchell
Software Engineer
Telogis
NOTICE:
