[Mapserver-users] Passing CGI variables
Dharani Babu
dharanibabus at hotmail.com
Fri Apr 16 01:06:26 EDT 2004
David
Really wonderful. Its running and I got the /temp image created . cool
thing. could you elaborate on how to set the REQUEST_METHOD etc
programmatically ?MY aim is to totally move the mapserv exe and its
dependencies out of IIS/ apache folders . I dont want to keep IIS or apache
running . I hope you have seen my method at my message on vb.net usage
http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/0404/msg00395.html?line=20#hilite
I am lacking to find the methods to find the methods to set the environment
variables programmatically .
with regards and thanks in advance
dharani
>From: David Mitchell <david.mitchell at telogis.com>
>To: Dharani Babu <dharanibabus at hotmail.com>
>CC: mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] Passing CGI variables
>Date: Fri, 16 Apr 2004 16:35:24 +1200
>Dharani,
>REQUEST_METHOD and QUERY_STRING are environment variables, not parameters
>to the application. Try this instead:
>C:\TEST>set "REQUEST_METHOD=GET"
>C:\TEST>set "QUERY_STRING=map=c:\....."
>C:\TEST>mapserv_40.exe
>David
>Dharani Babu wrote:
>>Hi David
>> Thanks . I moved all the contents of
>>C:/ms4w/apache/cgi-bin/mapserv_40.exe and all the other dlls into a folder
>>C:/test/ mapserv.exe . Ok . Now I passed the command paramaters like this
>>C:\TEST>mapserv_40.exe "REQUEST_METHOD = GET"
>>"QUERY_STRING=map=C%3A%2Fms4w%2Fapache%2Fhtdocs%2Fdemof%2Frock_pic.map&layer=tigerdata&zoomdir=1&zoomsize=2&progra
>>m=%2Fcgi-bin%2Fmapserv_40.exe&map_web_imagepath=C%3A%2Fms4w%2Fapache%2Fhtdocs%2Ftemp_rm6%2F&map_web_imageurl=%2Ftemp_rm6%2F"
>>I Got the following error .
>>This script can only be used to decode form results and
>>should be initiated as a CGI process via a httpd server.
>>I hope I am missing the syntax . I tried other combinations also still
>>missing.pls tell me the syntax of it .
>>with regard and thanks
>>dharani
>>>Date: Fri, 16 Apr 2004 13:43:08 +1200
>>>Dharani,
>>>If you want you can call mapserv directly as you wish but you have to
>>>first set the QUERY_STRING and REQUEST_METHOD environment variables to
>>>trick it into thinking it is being accessed through IIS:
>>>REQUEST_METHOD=GET
>>>QUERY_STRING="zoomdir=1&zoomsize=2..."
>>>That is all that IIS does anyway (not strictly true, IIS sets a few more
>>>variables and does a bit of house-keeping, but essentially the same). If
>>>your map has a template then the image will be in your temp folder and
>>>the std output of mapserv.exe will be the webpage (which you can throw
>>>away essentially).
>>>David
>>>Dharani Babu wrote:
>>>>Thanks Daniel - all
>>>> This helped me get a vb.net picture box based wrapper for the MS . I
>>>>have a question though .
>>>>As you when we post the CGI variables we are in need of posting it in
>>>>the form of a html stream only--like
>>>>"http://192.168.2.135/cgi-bin/mapserv_40.exe?zoomdir=1&zoomsize=2&" etc
>>>>. But is there any alternative so that I can pass it with
>>>>"C:/ms4w/apache/cgi-bin/mapserv_40.exe?zoomdir=1&zoomsize=2&" ?
>>>>But I know very well the map server exe works with Apache or IIS . But I
>>>>want to copy the map server exe and its associated dlls to a location
>>>>other then the cgi-bin or scripts . Is it possible ?
>>>>Is there any way we can make MS exe to get the html stream and give us
>>>>the image in tmp folder WITHOUT Apache or IIS ? I am trying to get a
>>>>soln by running dependency walker on ms exe and other trails with spy
>>>>tools . Still not yet solved .
>>>>dharani
>>>>>From: Daniel Morissette <dmorissette at dmsolutions.ca>
>>>>>Date: Sat, 10 Apr 2004 11:54:24 -0400
>>>>>Dharani Babu wrote:
>>>>>>1) I am trying to pass the CGI variables to the map server exe
>>>>>>without HTML submission .Thats I am trying to disassociate the browser
>>>>>>based rendering .Could any of you point to the direction ?I have been
>>>>>>able to pass the url thro a C# /VB.net web browser control . But
>>>>>>searching for an alternative . I tried passing CGI variables thro
>>>>>>command prompt but got a message that " cgi variables can be passed
>>>>>>only via httpd " .
>>>>>You can call the mapserv.exe at the command prompt using
>>>>> mapserv.exe "QUERY_STRING=map=/path/to/yourmap.map&mode=...&..."
>>>>>Daniel
>>>>> Daniel Morissette dmorissette at dmsolutions.ca
>>>>> DM Solutions Group http://www.dmsolutions.ca/
>>>>_________________________________________________________________
>>>>Contact brides & grooms FREE! http://www.shaadi.com/ptnr.php?ptnr=hmltag
>>>>Only on www.shaadi.com. Register now!
>>>>Mapserver-users mailing list
>>>>Mapserver-users at lists.gis.umn.edu
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>>David Mitchell
>>>Software Engineer
>>>Telogis
>>>NOTICE:
>>>This message (including any attachments) contains CONFIDENTIAL
>>>INFORMATION intended for a specific individual and purpose, and
>>>is protected by law. If you are not the intended recipient,
>>>you should delete this message and are hereby notified that any
>>>disclosure, copying, or distribution of this message, or the
>>>taking of any action based on it, is strictly prohibited.
>>Strike the right balance! News, gossip n fundas!
>>http://www.msn.co.in/women/ Get it all at MSN Women!
>David Mitchell
>Software Engineer
>Telogis
>NOTICE:
Post Classifieds on MSN classifieds. http://go.msnserver.com/IN/44045.asp
Buy and Sell on MSN Classifieds.
