[Mapserver-users] Help with Fatal Error received
Daniel Morissette
dmorissette at dmsolutions.ca
Fri Apr 16 09:10:16 EDT 2004
P Wilkerson wrote:
> The administrator for the site hosting my project has enabled PHP as a CGI
> to run
> MapScript. The script returns the phpinfo without reporting any errors.
> <?php dl("php_mapscript.so");
> phpinfo();
> Obviously, something is not working right. Suggestions??
Well, it seems that the CGI isn't kicking in for some reason.
Look at the "Server API" value close to the top of the phpinfo() output.
If it says anything other than "CGI" then your PHP CGI isn't working.
It could be that the Apache server has PHP builtin and in this case it
is used in priority to handle type application/x-httpd-php.
To force bypassing the PHP module and using the CGI, use a different
type, e.g.
AddType application/x-httpd-php-cgi .php .php4 .phtml
Action application/x-httpd-php-cgi /cgi-bin/php433
And make sure you remove any AddType lines for application/x-httpd-php
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
