[Mapserver-users] Mapserver demo error
Pericles S. Nacionales
nacional at cbs.umn.edu
Sun Apr 18 13:08:48 EDT 2004
Hi there!
Try these two things:
1. Make sure the /home/bahay/tmp/ is writeable by the Apache user
(usually apache or nobody).
2. If the above doesn't work, try moving /home/bahay/tmp directory to
/home/bahay/html_docs/tmp and changing the "map_web_imagepath" value in
your index.html accordingly.
The dhtml example works because it doesn't require the MapServer CGI
program to write anything to the tmp directory. This means your problem
is either a permission or a path problem. Or both.
Good luck!
-Perry
On Sun, 2004-04-18 at 09:07, ESSC Admin wrote:
> Hello everyone. I am having problems using the demo workshop.zip on my
> website. I uploaded everything, compiled them properly on a linux box
> and the demo works fine -- if you just pick the "-- Adds dhtml
> rubber-band box" and click initialize. Other than that, others like
> "basic application", "--Adds second scalebar", "--Adds pan
> control","--Adds frames", don't work properly. The png files don't
> show up. What could be the problem with this? You can test it at:
> http://bahayserver.net/mapserver/index.html Any help will is greatly
> appreciated. Thanks
> Regards to everyone.
> Essc Admin
"He's no geek.His tan's too good." -Benjamin Choate
