[Mapserver-users] Tolerance question ..
Murilo Lacerda Yoshida
murilo.yoshida at agx.com.br
Sun Apr 18 23:30:01 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C425A5.76A9AF40
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi all,
I have two questions now...
First one is about the tolerance I set on the map file. This tolerance
is like a radium around the user click? Like, if I set the tolerance to
5 pixels, it would be like if the user clicks on a point, I will query
everything in a 5 pixel radium, to all directions?
Second one is about the querybypoint method. My first attempt to use
tolerance on my map was setting it on the querybypoint method, so I put
a 5 on the last parameter. But this tolerance was looking like if it was
like 5000000000 kilometers.. In every point of the map I clicked I would
query something, even if it was very far from my click. Then I tried to
put a -1 on the last parameter, and put tolerance 5 on my map file. It
worked fine. But now I'm curious why the 5 of the querybypoint is so
different from the 5 of the map file.
Thanks,
Murilo
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C425A5.73223630">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EstiloDeEmail17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:70.85pt 3.0cm 70.85pt 3.0cm;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Tabela normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DPT-BR link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-US =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><span
style=3D'mso-spacerun:yes'> </span>Hi =
all,<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'> </span>I have two questions =
now...<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'> </span>First one is about the =
tolerance I set
on the map file. This tolerance is like <span class=3DGramE>a =
radium</span>
around the user click? Like, if I set the tolerance to 5 pixels, it =
would be
like if the user clicks on a point, I will query everything in <span
class=3DGramE>a 5</span> pixel radium, to all =
directions?<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'> </span>Second one is about the <span
class=3DSpellE>querybypoint</span> method. My first attempt to use =
tolerance on
my map was setting it on the <span class=3DSpellE>querybypoint</span> =
method, so
I put a 5 on the last parameter. But this tolerance was looking like if =
it was
like 5000000000 kilometers…. In every point of the map I clicked I =
would
query something, even if it was very far from my click. Then I tried to =
put a
-1 on the last parameter, and put tolerance 5 on my map file. It worked =
fine.
But now I’m curious why the 5 of the <span =
is so different from the 5 of the map =
file…<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'> =
</span>Thanks,<o:p></o:p></span></font></p>
style=3D'font-size:
</span>Murilo<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0001_01C425A5.76A9AF40--
