[Mapserver-users]View problem with overlaying WMS layers
Tommer
Tommer at seznam.cz
Mon Apr 19 06:46:06 EDT 2004
I'm using MapServer 4.02 and I have a problem with viewing of WMS connected layers from other servers. When only one WMS layer is on, everything is OK. But when I turn on more layers, only one is shown. Problem is not with transparency, all layers are transparent, because I can see local layers bellow, when only one remote layer is turned on. Sometimes, when I turn several times on and off one layer and the other one is on, this two layers are shown correctly. Sometimes the original layer turnes to grayscale, however. And sometimes is shown nothing at all. Is it problem on our side in the mapfile or in the MapServer? Or would it be problem with remote WMS connected server? Thank you for a help. Tom Mercl
Here is part of my map file.
MAP
NAME VODA
STATUS ON
SIZE 400 400
EXTENT -680105 -1074328 -616947 -1044180 #zobrazený výøez
UNITS METERS
SHAPEPATH "voda"
#IMAGECOLOR 255 255 255
TEMPLATEPATTERN "itasca"
IMAGETYPE GIF
TRANSPARENT TRUE
FONTSET "fonts/fonts.list"
# Webové rozhraní a WMS parametry
WEB
HEADER templates/header.html
TEMPLATE "set in index.html"
FOOTER templates/footer.html
#MINSCALE 1000
#MAXSCALE 1550000
IMAGEPATH "c:/mapserver/aplikace/tmp"
IMAGEURL "c:/mapserver/aplikace/tmp"
METADATA
WMS_TITLE "Pardubicko - vody"
WMS_ABSTRACT "Informaèní mapový server o ¾ivotním prostøedí pardubického regionu"
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://localhost.localdomain/mapserver_demos/itasca/index.html"
WMS_SRS "EPSG:2065"
END
END
LAYER # Zaèátek vrstvy
NAME pa-ot10
DATA pa-ot10
STATUS off
TYPE point
PROJECTION
"init=epsg:2065"
END
CLASS
NAME "Plavební komora"
COLOR 0 0 0
SYMBOL 'symboly/ot10.gif'
END
METADATA
WMS_TITLE "pa-ot10"
WMS_ABSTRACT "Plavební komora"
WMS_SRS "EPSG:2065"
END
END # Konec vrstvy
NAME pa-ot09
DATA pa-ot09
STATUS off
TYPE point
PROJECTION
"init=epsg:2065"
END
CLASS
NAME "Pøístav"
COLOR 0 0 0
SYMBOL 'symboly/kotva.gif'
END
METADATA
WMS_TITLE "pa-ot09"
WMS_ABSTRACT "Pøístav"
WMS_SRS "EPSG:2065"
END
END # Konec vrstvy
NAME znecisteni_vod_91_92
STATUS off
TYPE raster
#TRANSPARENCY 50
OFFSITE 255 255 255
PROJECTION
"init=epsg:2065"
END
CONNECTIONTYPE WMS
CONNECTION "http://www.utpcr.cz/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?WMTVER=1.0.0&SERVICENAME=environmental_degradation&REQUEST=getmap&SERVICE=WMS&LAYERS=8&TRANSPARENT=false&FORMAT=PNG&SRS=EPSG:2065"
CLASS
NAME "Stupeò zneèi¹tìní vody 91/92"
#COLOR 255 255 0
END
METADATA
WMS_TITLE "8"
WMS_ABSTRACT "Contamination degree of water pollution 91/92"
WMS_SRS "EPSG:2065"
END
END # Konec vrstvy
NAME vodni_plochy
STATUS off
TYPE raster
#TRANSPARENCY 50
OFFSITE 255 255 255
PROJECTION
"init=epsg:2065"
END
CONNECTIONTYPE wms
CONNECTION "http://www.utpcr.cz/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?WMTVER=1.0.0&SERVICENAME=environmental_degradation&REQUEST=getmap&SERVICE=WMS&LAYERS=15&TRANSPARENT=false&FORMAT=png&SRS=EPSG:2065"
CLASS
NAME "Vodní plochy"
#COLOR 255 255 0
END
# METADATA
# WMS_TITLE "15"
# WMS_ABSTRACT "Water surfaces"
# WMS_SRS "EPSG:2065"
# END
END # Konec vrstvy
END # Konec mapy
____________________________________________________________
Jak mù¾e být perfektní SIEMENS C62 je¹tì pefektnìj¹í? Co tøeba takhle - SIEMENS C62 za 977,- Kè. www.oskar.cz
http://ad.seznam.cz/clickthru?spotId=73597§ion=/
