RES: [Mapserver-users] Tolerance question ..
Murilo Lacerda Yoshida
murilo.yoshida at agx.com.br
Mon Apr 19 14:29:27 EDT 2004
Thanks for the answer... And I coded your suggestion, it worked fine.
Thanks a lot...
Murilo
-----Mensagem original-----
De: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu] Em nome de Norbert
Thieme
Enviada em: segunda-feira, 19 de abril de 2004 04:20
Para: murilo.yoshida at agx.com.br
Cc: mapserver-users at lists.gis.umn.edu
Assunto: Re: [Mapserver-users] Tolerance question ..
Murilo Lacerda Yoshida schrieb:
> Hi all,
> I have two questions now...
> First one is about the tolerance I set on the map file. This
tolerance
> is like a radium around the user click? Like, if I set the tolerance
to
> 5 pixels, it would be like if the user clicks on a point, I will query
> everything in a 5 pixel radium, to all directions?
> Second one is about the querybypoint method. My first attempt to use
> tolerance on my map was setting it on the querybypoint method, so I
put
> a 5 on the last parameter. But this tolerance was looking like if it
was
> like 5000000000 kilometers.. In every point of the map I clicked I
would
> query something, even if it was very far from my click. Then I tried
to
> put a -1 on the last parameter, and put tolerance 5 on my map file. It
> worked fine. But now I'm curious why the 5 of the querybypoint is so
> different from the 5 of the map file.
> Thanks,
> Murilo
Sorry I missed an important point:
The tolerance in the mapfile depends on the definition of the
toleranceunits. If toleranceunits is not set then it is in pixel.
If you use a tolerance in the querybypoint function <= 0 then mapscript
uses the value set in the mapfile.
In the other case (tolerance > 0) the tolerance in the querybypoint
function have to be in georeferenced map coordinates.
And yes, I think it is the definition of the radius for a buffer around
the pointObj where you make a click.
Regards,
Norbert
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
