[Mapserver-users] GPS data Projection
Gerry Creager N5JXS
gerry.creager at tamu.edu
Mon Apr 26 01:43:05 EDT 2004
Several things to consider.
1. What datum is the GPS configured to display
1a. When so configured, does it also output the data in that datum from
its memory (this is not as obvious as it seems with some consumer-grade
GPS receivers).
2. You can generally use WGS84 data (default GPS datum) on top of NAD83
maps. You may see a small error associated with the differences
between the 2 datums, but it should be of little importance unless your
data are already of high accuracy... say, at the centimeter level.
You will have to add a reference for the mapfile to the correct
datum/projection in use in a Projection section (init=epsg:26915) and
similarly, in the GPS layer, a Projection section referencing
'init=epsg:4326' as well as identifying, in the GPS layer, units as degrees.
I've probably missed something, but it's late.
gerry
Changqing Zhou wrote:
> HI, I would greatly appreaciate your help on a projection question:
> How do I display gps data in lat-long point format on top of the following
> MNDOT base road shapefile? How to project the GPS data to the road map system?
> (http://www.dot.state.mn.us/tda/basemap/metadata/Roads.htm)
> Horizontal Coordinate Scheme UTM
> Ellipsoid GRS80
> Horizontal Datum NAD83
> Horizontal Units Meters
> Below is my simplified maplefile. Note I do not use any projections:
> MAP
> NAME Hennepin County
> IMAGETYPE png
> #EXTENT 201621.496941 -294488.285333 1425518.020722
> 498254.511514 # LAEA
> EXTENT 439000 4960000 487000 5010000 #from arcview
> #EXTENT -97.5 41.619778 -82.122902 49.38562 # Geographic
> SIZE 800 600
> SHAPEPATH "data"
> SYMBOLSET "symbols/symbols35.sym"
> FONTSET "fonts/fonts.list"
> WEB
> TEMPLATE 'hennepinRoads.html'
> IMAGEPATH '/ApacheGroup/Apache2/htdocs/tmp/'
> IMAGEURL '/tmp/'
> END
> PROJECTION
> # This is Lambert Azimuthal Equal-Area projection for the
> # Continental U.S.
> # "proj=laea"
> # "ellps=clrk66"
> # "lat_0=45"
> # "lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> # This is the EPSG code for
> # Lambert Azimuthal Equal-Area projection for the U.S.
> #"init=epsg:2163"
> END
> LAYER # Hennepin Road layer begins here
> NAME hennepin_line
> DATA hennepinm
> STATUS DEFAULT
> TYPE LINE
> # PROJECTION
> # "init=epsg:4326"
> # END
> CLASSITEM "Code"
> CLASS
> EXPRESSION '01'
> COLOR 0 0 255
> END
> CLASS
> EXPRESSION '02'
> COLOR 0 0 255
> END
> CLASS
> EXPRESSION '03'
> COLOR 255 0 0
> END
> CLASS
> EXPRESSION '04'
> COLOR 0 255 255
> END
> END # Hennepin Roads layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> END # end of map file
> Thanks,
> Changqing
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
