[Mapserver-users] Image not visible
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Mon Apr 26 02:54:10 EDT 2004
did you try to use the map->save function? With this you get a mapfile
out of your current mapobject. There you can look if everything is correct.
Regards,
Norbert
Attri, Abhishek schrieb:
> Hi All,
> I am trying to use mapscript to display a simple image. When I add the
> layers and classes in the mapfile, I get the image. But, when I try to
> create the layers and classes through the mapscript, I get the image
> which is not visible. Can somebody help me find out what I am doing wrong?
> Here is the code for mapfile and mapscript file:-
> NAME FIRSTMAP
> SIZE 500 500
> STATUS ON
> SYMBOLSET ../symbols/symbols35.sym
> EXTENT -88.50 30.23 -84.88 35.02
> UNITS MILES
> SHAPEPATH "../data"
> WEB
> IMAGEPATH "/home/tech/abhi/WWW/tmp/"
> IMAGEURL "/tmp/"
> END
> END
> <?php
> dl('php_mapscript.so');
> $map_path="/home/tech/abhi/WWW/ms/map_files/";
> $map_file="./Newcounty.map";
> $map = ms_newMapObj($map_path.$map_file);
> // create layer
> $layer = ms_newLayerObj($map);
> $layer->{name} = "Counties";
> $layer->{type} = MS_POLYGON;
> $layer->{status} = MS_ON;
> $layer->{data} = "./counties";
> // create class
> $class = ms_newClassObj($layer);
> $class->{status}= MS_ON;
> $class->{name}= "Myclass";
> $style = ms_newStyleObj($class);
> $style->{color}->{red}= 110;
> $style->{color}->{blue}= 50;
> $style->{color}->{green}= 100;
> $style->{outlinecolor}->{red}= 200;
> $style->{outlinecolor}->{blue}= 200;
> $style->{outlinecolor}->{green}= 200;
> $style->{symbol} =0;
> //Draw Image
> $image=$map->draw();
> $image_url=$image->saveWebImage();
> <HTML>
> <HEAD>
> <TITLE>Map 1</TITLE>
> </HEAD>
> <BODY>
> <center>
> <TABLE>
> <TR><td>
> <INPUT TYPE=IMaGe name=mapa src=<?php echo $image_url?>>
> </td></TR>
> </TABLE>
> <center>
> </BODY>
> </HMTL>
> With thanks in advance,
> Abhishek
