[Mapserver-users] how to turn off central point for labels (or how not to draw them for attribute=0) ?
Michael Schulz mschulz at webgis.de
Mon Apr 26 06:32:56 PDT 2004
Hi Moritz,
even if the value for the LABELSIZEITEM attribute is 0/NULL, there is a
point that then gets the default label, which is for point type layers a
single pixel. To avoid this you could try to filter your data at the
layer level, so that your layer only conatins points, that have a
meanigful value for the LABELSIZEITEM attribute, e.g. something like
FILTER ([YOUR_LABELSIZEITEM_ATTRIBUTE] > 0)
HTH, Michael
Moritz Lennert schrieb:
> Hello,
> I am trying to draw point symbols proportionate to a given attribute. I
> use LABELSIZEITEM to do this (thanks to Jan Hartmann for the tip) and it
> works like a charm.
> The only problem I have is that when the attribute column contains zeros
> (or NULLS, but in a dbf-file nulls seem to be 0s), instead of seeing
> nothing in those places where the attribute is zero I still get a tiny
> central point taht looks like a label anchoring point.
> Where there is a value for the attribute the central point is covered by
> the symbol. If my explanation is not clear, please see here:
> http://moritz.homelinux.org/misc/mapserver_central_label_points.png
> Is there a way to turn these central points off ?
> Moritz
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Michael Schulz                                in medias res
Dipl.-Geologe                              Gesellschaft für
                                 Informationstechnologie mbH
                                      In den Weihermatten 66
		                             79108 Freiburg
                                      0761 55695-95 (Fax 96)
mschulz at webgis.de              www.webgis.de/www.zopecms.de
More information about the MapServer-users mailing list
