[Mapserver-users] complex postgis queries in mapserver
Pericles S. Nacionales
nacional at cbs.umn.edu
Tue Apr 27 15:41:38 EDT 2004
Do you have a postgresql log that you can check for error messages?
Check that your user account have SELECT privileges on both tables.
This is an oft-forgotten hint.
-Perry
On Tue, 2004-04-27 at 13:29, andreas.mueller at bfua.de wrote:
> Hi,
> although there has been a lot of mails about this problem I still don't figure it out.
> When I enter a simple query:
> DATA "the_geom FROM ruhr"
> I get a nice map.
> But if I do a join on two tables in the same way as the documentation (and about 5
> million mails from this list) says, I get the well known error message:
> msDrawMap(): Image handling error. Failed to draw layer named 'ruhr'.
> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query)
> statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> hp1::text,asbinary(force_collection(force_2d(x3x3)),'NDR'),oid::text from
> x3x3 WHERE x3x3 && setSRID('BOX3D(2510000
> 5608433.33333333,2680000 5778566.66666667)'::BOX3D, -1 )'
> and so on
> The subquery is fine for PostgreSQL. We have an alias for the result set. We use "oid"
> as UNIQUE and "SRID" as well.
> The layer definition is as follows:
> LAYER
> NAME ruhr
> TYPE POLYGON
> CONNECTIONTYPE postgis
> CONNECTION "user=andy dbname=mygisdb host=localhost password=harry"
> DATA "the_geom FROM (SELECT ruhr.oid AS oid, ruhr.the_geom AS the_geom,
> ruhr_small.hp1 AS hp1 FROM ruhr LEFT JOIN ruhr_small ON ruhr.gewkz =
> ruhr_small.gewkz AND ruhr.stat = ruhr_small.abschnitt ) AS test USING UNIQUE oid
> USING SRID=-1"
> STATUS DEFAULT
> CLASSITEM hp1
> CLASS
> EXPRESSION "1"
> My Mapserver version is running on my Win 2k desktop:
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I'm running PostGIS 0.81 and PostgreSQL 7.4.1.3 within Cygwin.
> Where is the mistake?
> Thanks
> Andreas
"He's no geek.His tan's too good." -Benjamin Choate
