[Mapserver-users] QueryByAttribute
Ryan, Adam
ARyan at co.linn.or.us
Wed Apr 28 08:39:59 PDT 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C42D37.10966740
Content-Type: text/plain
Just a hunch, I needed parentheses. Instead of
$oQueryStatus = $oPincodeLayer->queryByAttributes("OUT_CODE",
"\"".$szPincode."\"",MS_SINGLE);
try
"(\"".$szPincode."\")",MS_SINGLE);
Hope it helps,
Adam
-----Original Message-----
From: Satyajit [mailto:satyajit.gantayat at aurovision.com]
Sent: Wednesday, April 28, 2004 12:39 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] QueryByAttribute
Hi Folks,
I have been banging my head since a couple of days with this code. I
am trying to build an application where the user can search for a specific
postcode and then the map will zoom into that particular extent.
When the user enters a postcode ( I call it PINCODE) in the inputbox we
search the pincode in the pincode shape file and set the map's extent to
that of the shape found.
But the following code is not working. The queryByAttributes function is
reporting MS_FAILURE. This code is some what similar to that in one of the
listings. It would beb great if somebody guide me through step by step
procedure of developing this kind of QueryByAttribute feature using
Mapserver.
if ($http_form_vars["Pincode"])
// the pincode to query for
$szPincode = $http_form_vars["Pincode"];
$oPincodeLayer = $oMapSession->oMap->getLayerByName("Pincode");
// OUT_CODE is the field name which contains the value which would be
queried.
if ( $oQueryStatus = MS_FAILURE )
echo "<td ><b> Query Failed ... \"".$szPincode."\" </b></td>";
echo "<td> Query Status = ".$oQueryStatus."</td>";
else
if ($oPincodeLayer->getNumResults() > 0)
$oResult = $oPincodeLayer->getResult(0);
$oOpen = $oPincodeLayer->open();
$oShape = $oPincodeLayer->getShape($oResult->tileindex,
$oResult->shapeid);
$oExtents = $oShape->bounds;
$oShape->free();
//at this point we might add a buffer to the extents
$nMinX = $oExtents->minx;
$nMaxX = $oExtents->maxx;
$nMinY = $oExtents->miny;
$nMaxY = $oExtents->maxy;
$oExtents->setExtent( $nMinX, $nMinY, $nMaxX, $nMaxY );
// now use $oMapNavigator to navigate to the parcel
// location. There are two useful options now. We
// can zoom to a rectangle which we have calculated or
// to a point and scale. Let's assume we have calculated
// a rectangle and put a buffer around it if necessary.
//$oMapNavigator->zoomRectangle($nMinX, $nMinY,
//$nMaxX, $nMaxY);
$oMapSession->oMap->setExtent( $oExtents->minx, $oExtents->miny,
$oExtents->maxx, $oExtents->maxy );
I am using
MapServer/MapScript 4.0
PHP 4.3
MapLab 2.1
Thanks and Regards
Satyajit G.
Imaging the way ahead ...
Satyajit Gantayat
Sr. Specialist GIS
Aurovision Pvt. Ltd.
101, Swati
North Avenue
Santacuz (w)
Mumbai - 400054
India
tel: 91-22-56982010
<https://www.plaxo.com/add_me?u=25769950220&v0=291241&k0=719474838>
Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=us-ascii">
<TITLE>Message</TITLE>
<META content="MSHTML 6.00.2800.1400" name=GENERATOR></HEAD>
<BODY>
<DIV>
<DIV><FONT face=Arial color=#0000ff size=2></FONT> </DIV>
<DIV><SPAN class=890484515-28042004><FONT face=Arial color=#0000ff size=2>Just a
hunch, I needed parentheses. Instead of </FONT></SPAN></DIV>
size=2></FONT></SPAN> </DIV>
<DIV><SPAN class=890484515-28042004><FONT face=Verdana color=#0000ff
size=2>$oQueryStatus = $oPincodeLayer->queryByAttributes("OUT_CODE",
"\"".$szPincode."\"",MS_SINGLE);</FONT><BR></SPAN></DIV>
size=2>try</FONT></SPAN></DIV>
"(\"".$szPincode."\")",MS_SINGLE);</FONT><BR></SPAN></DIV>
<DIV><SPAN class=890484515-28042004><FONT face=Arial color=#0000ff size=2><SPAN
class=890294715-28042004>Hope it helps,</SPAN></FONT></SPAN></DIV>
size=2>Adam</FONT></DIV></SPAN>
<DIV><FONT face=Arial color=#0000ff size=2></FONT> </DIV></DIV>
<BLOCKQUOTE dir=ltr style="MARGIN-RIGHT: 0px">
<DIV></DIV>
<DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><FONT
face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Satyajit
[mailto:satyajit.gantayat at aurovision.com] <BR><B>Sent:</B> Wednesday, April
28, 2004 12:39 AM<BR><B>To:</B>
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> [Mapserver-users]
QueryByAttribute<BR><BR></FONT></DIV>
<DIV><SPAN class=702320412-27042004><FONT face=Verdana><FONT size=2><SPAN
class=859083807-28042004><FONT color=#0000ff> </FONT><FONT
color=#000000>H</FONT></SPAN>i Folks,</FONT></FONT></SPAN></DIV>
<DIV><FONT face=Verdana size=2><SPAN
class=702320412-27042004> I have been
banging my head since a couple of days with this code. I am trying to
build an application where the user can search for a specific postcode and
then the map will zoom into that particular extent. </SPAN></FONT></DIV>
<DIV><FONT face=Verdana size=2> When the user enters a p<SPAN
class=702320412-27042004>ostcode ( I call it PINCODE) in the
inputbox</SPAN><SPAN class=702320412-27042004> </SPAN>we search the
pincode in the pincode sh<SPAN class=702320412-27042004>a</SPAN>p<SPAN
class=702320412-27042004>e</SPAN> file and set the map's extent to that of
the shape found.<BR>But the following code is not working. The
queryByAttributes function is reporting MS_FAILURE. This code is some what
similar to that in one of the listings. <SPAN
class=702320412-27042004>It would beb great if somebody guide
me </SPAN><SPAN class=702320412-27042004>through</SPAN> step by step
procedure<SPAN class=702320412-27042004> </SPAN>of developing this kind
of <SPAN class=702320412-27042004>Q</SPAN>uery<SPAN
class=702320412-27042004>B</SPAN>y<SPAN
class=702320412-27042004>A</SPAN>ttribute feature using
Mapserver.</FONT></DIV>
<DIV><FONT face=Verdana size=2></FONT> </DIV>
<DIV><FONT face=Verdana color=#0000ff size=2>if
($http_form_vars["Pincode"])<BR>{<BR> // the pincode to query
for<BR> $szPincode =
$http_form_vars["Pincode"];<BR> <BR> $oPincodeLayer =
$oMapSession->oMap->getLayerByName("Pincode");<BR> <BR><SPAN
class=702320412-27042004>// OUT_CODE is the field name which contains the
value which would be queried.</SPAN> </FONT></DIV>
<DIV><FONT face=Verdana color=#0000ff size=2></FONT> </DIV>
<DIV><FONT face=Verdana color=#0000ff size=2>$oQueryStatus =
"\"".$szPincode."\"",MS_SINGLE);<BR> <BR> if ( $oQueryStatus =
MS_FAILURE )<BR> {<BR> echo "<td ><b>
</b></td>";<BR> echo "<td> Query Status =
".$oQueryStatus."</td>";<BR> }<BR> else<BR> {<BR> if
0)<BR> {<BR> $oResult =
$oPincodeLayer->getResult(0);<BR> $oOpen =
$oPincodeLayer->open();<BR> <BR> $oShape
$oResult->shapeid);<BR> <BR> $oExtents
$oShape->bounds;<BR> <BR> $oShape->free();<BR> <BR> //at
this point we might add a buffer to the extents<BR> $nMinX
= $oExtents->minx;<BR> $nMaxX =
$oExtents->maxx;<BR> $nMinY =
$oExtents->miny;<BR> $nMaxY =
$oExtents->maxy;<BR> <BR> $oExtents->setExtent(
$nMinX, $nMinY, $nMaxX, $nMaxY );<BR> }<BR> // now use
$oMapNavigator to navigate to the parcel<BR> // location.
There are two useful options now. We<BR> // can zoom to a
rectangle which we have calculated or<BR> // to a point and
scale. Let's assume we have calculated<BR> // a rectangle
necessary.<BR> //$oMapNavigator->zoomRectangle($nMinX,
$nMinY,<BR> //$nMaxX,
$nMaxY);<BR> $oMapSession->oMap->setExtent(
$oExtents->minx, $oExtents->miny, $oExtents->maxx,
$oExtents->maxy );<BR> }<BR>}</FONT></DIV>
<DIV><BR><FONT face=Verdana><FONT size=2> <SPAN
class=702320412-27042004>I am using</SPAN></FONT></FONT></DIV>
<DIV><FONT face=Verdana><FONT size=2><SPAN
class=702320412-27042004> MapServer/MapScript
4.0</SPAN></FONT></FONT></DIV>
class=702320412-27042004> PHP
4.3</SPAN></FONT></FONT></DIV>
class=702320412-27042004> MapLab
2.1</SPAN></FONT></FONT></DIV>
class=702320412-27042004> </SPAN></FONT></FONT></DIV>
class=702320412-27042004></SPAN></FONT></FONT> </DIV>
<DIV><FONT face=Verdana><FONT size=2><SPAN class=702320412-27042004>Thanks
and Regards</SPAN></FONT></FONT></DIV>
<DIV><FONT face=Verdana><FONT size=2><SPAN class=702320412-27042004>Satyajit
G.</SPAN></FONT></FONT></DIV>
<STYLE>A.psl {
COLOR: #4e81c4; TEXT-DECORATION: none
A:hover {
TEXT-DECORATION: underline
A.psl:hover {
COLOR: #999999
.noro {
FONT-SIZE: 8pt; COLOR: #4e81c4; FONT-FAMILY: Verdana,Arial,fixed
.tiny {
FONT-SIZE: 1pt
.logotext {
FONT-SIZE: 10pt; FONT-FAMILY: Verdana,Arial,fixed; TEXT-DECORATION: none
A.brand {
FONT-SIZE: 7pt; COLOR: #777777; FONT-FAMILY: Verdana,Arial,fixed; TEXT-DECORATION: none
</STYLE>
<DIV align=left>
<TABLE cellSpacing=0 cellPadding=0 width=320 border=0>
<TBODY>
<TR>
<TD>
<TABLE height=80 cellSpacing=0 cellPadding=0 width=320 align=right
border=0>
<TBODY>
<TR>
<TD class=tiny>
<TABLE
style="BORDER-RIGHT: #666666 1px solid; BORDER-TOP: #666666 1px solid; BORDER-LEFT: #666666 1px solid; BORDER-BOTTOM: #666666 1px solid"
height="100%" cellSpacing=0 width=320>
<TBODY>
<TR bgColor=#ffffff>
<TD class=tiny width="100%" height=1>
<TABLE cellSpacing=0 cellPadding=1 width="100%"
border=0><TBODY>
<TR>
<TD class=logotext style="PADDING-LEFT: 5px"></TD>
<TD class=noro
style="PADDING-RIGHT: 5px; FONT-SIZE: 7pt"
align=right><FONT size=1>Imaging the way ahead
...</FONT></TD></TR></TBODY></TABLE></TD>
<TD class=tiny></TD></TR>
<TR>
<TD colSpan=2>
<TABLE style="WIDTH: 358px; HEIGHT: 113px" height=113
cellSpacing=2 width=358 align=right border=0>
<TBODY>
<TR style="PADDING-BOTTOM: 4px" height=1>
<TD class=noro style="PADDING-LEFT: 4px"
vAlign=top><FONT size=2><B>Satyajit
Gantayat</B><BR><FONT face=v><EM>Sr. Specialist
GIS</EM></FONT></FONT> </TD>
<TD class=noro style="PADDING-RIGHT: 4px" vAlign=top
align=right>
<DIV><FONT size=2><B>Aurovision Pvt.
Ltd.</B><BR>101, Swati<BR>North Avenue<BR>Santacuz
(w)<BR>Mumbai - 400054</FONT></DIV>
<DIV><FONT size=2>India </FONT></DIV></TD></TR>
<TR height=1>
<TD class=noro
style="PADDING-LEFT: 4px; PADDING-BOTTOM: 4px"
vAlign=bottom><FONT size=2></FONT></TD>
<TD class=noro
style="PADDING-RIGHT: 4px; PADDING-BOTTOM: 4px"
vAlign=bottom align=right>
<TABLE cellSpacing=0 align=right border=0>
<TBODY>
<TR>
<TD class=noro noWrap align=right><FONT
size=2>tel: </FONT></TD>
<TD class=noro style="PADDING-LEFT: 4px" noWrap
align=right><FONT size=2>91-22-56982010</FONT>
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD>
<TD style="BACKGROUND-REPEAT: repeat-y" vAlign=top width=6
background=http://www.plaxo.com/images/card_shadow2_right_middle.gif
height="100%">
<TABLE cellSpacing=0 cellPadding=0 border=0>
<TBODY>
<TR>
<TD style="BACKGROUND-REPEAT: no-repeat" width=6
background=http://www.plaxo.com/images/card_shadow2_right_top.gif
height=7> </TD></TR></TBODY></TABLE></TD></TR>
<TR>
<TD class=tiny style="BACKGROUND-REPEAT: repeat-x"
background=http://www.plaxo.com/images/card_shadow2_bottom_middle.gif>
<TABLE class=tiny cellSpacing=0 cellPadding=0 width="100%"
<TBODY>
<TR>
<TD class=tiny style="BACKGROUND-REPEAT: no-repeat"
vAlign=top width=8
background=http://www.plaxo.com/images/card_shadow2_bottom_left.gif
height=6></TD>
vAlign=top
height=6> </TD></TR></TBODY></TABLE></TD>
<TD class=tiny style="BACKGROUND-REPEAT: no-repeat" vAlign=top
width=7
background=http://www.plaxo.com/images/card_shadow2_bottom_right_corner.gif
height=6></TD></TR></TBODY></TABLE></TD></TR>
<TR>
<TD class=tiny colSpan=2></TD></TR>
<TR>
<TD align=middle colSpan=2><FONT face=Verdana size=2></FONT><A
class=brand
href="https://www.plaxo.com/add_me?u=25769950220&v0=291241&k0=719474838"
target=_blank><I></I></A></TD></TR></TBODY></TABLE></DIV>
<DIV> </DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C42D37.10966740--
More information about the MapServer-users
