[Mapserver-users] Image not visible
Attri, Abhishek
aattri at cba.ua.edu
Thu Apr 29 00:41:27 EDT 2004
I saved the new mapfile in the temp directory. The mapscript code is
not adding any layers and classes, and I still get a blank image.
Here are the three sample codes for the input mapfile, mapscript file,
and the output map file.
*********INPUT Map File************
MAP
NAME FIRSTMAP
SIZE 500 500
STATUS ON
SYMBOLSET /home/tech/abhi/WWW/ms/symbols/symbols35.sym
EXTENT -88.50 30.23 -84.88 35.02
#UNITS MILES
SHAPEPATH "/home/tech/abhi/WWW/ms/data"
WEB
IMAGEPATH "/home/tech/abhi/WWW/tmp/"
IMAGEURL "/tmp/"
END
END
*************mapscript************************
<?php
dl('php_mapscript.so');
$map_path="/home/tech/abhi/WWW/ms/map_files/";
$map_file="Newcounty.map";
$map = ms_newMapObj($map_path.$map_file);
$map->{name} = 'Test';
$map->{status} = MS_ON;
$map->{height} = 400;
$map->{width} = 400;
$map->{interlace} = MS_OFF;
$map->{transparent} = MS_OFF;
$map->{shapepath} = "/home/tech/abhi/WWW/ms/data";
$map->{imagecolor}->{red} = 255;
$map->{imagecolor}->{green} = 200;
$map->{imagecolor}->{blue} = 255;
$ext = ms_newRectObj();
$ext->{minx} = -88.50;
$ext->{miny} = 30.23;
$ext->{maxx} = -84.88;
$ext->{maxy} = 35.02;
$map->{extent} = $ext;
// create layer
$layer = ms_newLayerObj($map);
$layer->{name} = "world";
$layer->{type} = MS_POLYGON;
$layer->{status} = MS_ON;
$layer->{data} = "counties";
$layer->{tolerance} = 10;
// create class
$class = ms_newClassObj($layer);
$class->{status}= MS_ON;
$class->{name}= "Myclass";
$style = ms_newStyleObj($class);
$style->{color}->{red}= 110;
$style->{color}->{green}= 100;
$style->{color}->{blue}= 50;
$style->{outlinecolor}->{red}= 200;
$style->{outlinecolor}->{green}= 200;
$style->{outlinecolor}->{blue}= 200;
//$style->{symbol} =0;
//Draw Image
$i= $map->save("/home/tech/abhi/WWW/tmp/finalTest.map");
if ($i != -1){
$image=$map->draw();
//$map->{imagecolor}= $map->addColor(0,0,255);
$image_url=$image->saveWebImage();
<HTML>
<HEAD>
<TITLE>Map 1</TITLE>
</HEAD>
<BODY>
<center>
<TABLE>
<TR><td>
<INPUT TYPE=IMaGe name=mapa src=<?php echo $image_url?>>
</td></TR>
</TABLE>
<center>
</BODY>
</HMTL>
output map file in the temp folder
MAP
EXTENT -88.5 30.23 -84.88 35.02
IMAGECOLOR 255 255 255
IMAGETYPE png
SYMBOLSET "/home/tech/abhi/WWW/ms/symbols/symbols35.sym"
SIZE 500 500
STATUS ON
UNITS METERS
NAME "FIRSTMAP"
OUTPUTFORMAT
NAME png
MIMETYPE image/png
DRIVER GD/PNG
EXTENSION png
IMAGEMODE PC256
TRANSPARENT FALSE
END
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION CC
END
POSITION LL
STATUS OFF
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
SCALEBAR
COLOR 0 0 0
INTERVALS 4
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
SIZE 200 3
STATUS OFF
STYLE 0
UNITS MILES
END
WEB
IMAGEURL "/tmp/"
END
LAYER
NAME "(null)"
SIZEUNITS PIXELS
STATUS OFF
TOLERANCE 0
TOLERANCEUNITS PIXELS
UNITS METERS
CLASS
STYLE
MAXSIZE 100
MINSIZE 1
SIZE 1
SYMBOL 0
END
END
END
END
Somebody please help me understand, what I am doing wrong in
implementing such a simple thing.
Thanks a lot..........
Abhishek
-----Original Message-----
From: Norbert Thieme [mailto:norbert.thieme at ilmenau.baw.de]
Sent: Tuesday, April 27, 2004 2:22 AM
To: Attri, Abhishek
Subject: Re: [Mapserver-users] Image not visible
Attri, Abhishek schrieb:
> Hi there!
> When I try to use the map->save method, I get the following error:-
> Fatal error: [MapServer Error]: msSaveMap()
> :(/home/tech/abhi/WWW/ms/map_files/filename.map) in
> /home/tech/aattri/public_html/mapExamples/Maptest.php on line --
> I am not able to color the map. It just shows a blank image, probably
> the part that it reads from the map file itself. But the classes that
I
> add through the map script are not displayed. Please help me with
that.
> With thanks a lot...
> Abhishek
I think that the problem with the save function is that you try to put
it in your mapfile folder. But when I see it right the mapserver has no
permissions to write in that folder. Simply try to use your mapserver
temp directory.
Regards,
Norbert
