[Mapserver-users] trouble compiling mapserver with ogr
Moritz Lennert
mlennert at club.worldonline.be
Thu Apr 29 05:53:42 EDT 2004
Moritz Lennert said:
> Frank Warmerdam said:
>> Moritz Lennert wrote:
>>> All of them resulting in the same compile error:
>>> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>> -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_JPEG -DUSE_GD_PNG
>>> -DUSE_GD_JPEG
>>> -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_PDF -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS
>>> -I/usr//include -I/usr/include -I/usr/include
>>> -I/usr/include/postgresql shp2img.o -L. -lmap -L/usr//lib -lgd
>>> -ljpeg
>>> -lfreetype -lpng -lz -lpdf -ljpeg -lfreetype -lpng -lz -lproj
>>> -ljpeg
>>> -L/usr/lib -lgdal -L/usr/lib -lpq -lm -lstdc++ -o shp2img
>>> ./libmap.a(mapogr.o)(.text+0x15b): dans la fonction «
>>> ogrGeomPoints(OGRGeometry*, shapeObj*) »:
>>> : undefined reference to `OGRGeometryCollection::getNumGeometries()'
>>> ./libmap.a(mapogr.o)(.text+0x2b7): dans la fonction «
>> Hi,
>> Is there any possibility that the OGR on your system was built with a
>> difference version of gcc than you are using for MapServer? C++ linkage
>> naming conventions in object code have varied somewhat between versions
>> of
>> gcc, so if you are using a different gcc than was used to build
>> GDAL/OGR,
>> then
>> you might get surprising issues like the above. This is especially
>> common
>> if
>> you got the GDAL/OGR from some other source (ie. RPMs or .deb's from
>> elsewhere).
>> If this is the issue, then I would suggest you build and install
>> GDAL/OGR
>> from source on your system.
> I did build GDAL/OGR from CVS sources on my system, and both config logs
> show: gcc (GCC) 3.3.3 20040125 (prerelease) (Debian).
A little correction: I actually built gdal with Debian's
dpkg-buildpackage. I'm not sure wether it writes to config.log or whether
the config.log was from a previous manual run of configure. So I'm not
100% sure of which gcc version was used...
Moritz
