[Mapserver-users] WMS mapfile snippet/WMS test server
Nicolas Boretos
nicolas at maich.gr
Thu Apr 29 06:59:35 EDT 2004
>> Do I need anything in my WEB object?
>> Could someone supply a valid snippet that tests the WMS servers
>> posted at postgis site?
>> regards,
>> nicolas
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> I think you need at least the imagepath in the web object because the
> mapserver creates a temporary image in this directory and deletes it.
The above is snipped out of my mapfile. The other layers work, meaning I
have the image path in my web object
web
footer "kaz_png_footer.html"
header "kaz_png_header.html"
imagepath "c:/web/maich.gr/kaz_png/tmp/"
imageurl "/kaz_png/tmp/"
template "kaz_png.html"
end
> Do you have a projection set for your map? You need to have that. If
> you have it how does it look like?
No, I dont have a projection set, but my shape file stuff works
I just blindly tried adding
PROJECTION
"proj=utm"
"ellps=GRS80"
"zone=15"
"north"
"no_defs"
END
and my shape stuff still works...
I dont know...
regards,
nicolas
