[Mapserver-users] Info: compiling 4.2b on FreeBSD fails
Daniel Morissette
dmorissette at dmsolutions.ca
Fri Apr 30 09:04:22 PDT 2004
Eric Bridger wrote:
> We face the same issue and use gdal/ogr only within mapserver. Any
> reason to avoid gdal-1.2.0?
GDAL 1.2.0 works great for us.
The only problem may be the new libtool-based build system that may not
have been tested on all the esoteric platforms (for instance AIX didn't
work very smoothly). However if you run into problems then you can use
the --without-libtool configure switch (and report the problems you
found to the GDAL list).
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
More information about the MapServer-users
