[Mapserver-users] demo: legend, scalebar
malonso at meso.com
malonso at meso.com
Fri Apr 30 13:15:36 EDT 2004
--MIMEStream=_0+165804_926459201569_788237211875
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
Howdy all,
I am trying to run the demo, and I can get most of it to work, but I can't
seem to get the legend or the 1st scalebar, the main map and the 2nd bar
in the bottom right corner works fine. I attached the modified index.html
and itasca.map files. Ironically I had them all working fine at first,
but I had set the various "image_" things wrong so I could not see them.
I made a couple changes and looked in the dir where the images should've
been and they were all there. All the previous legends and scalebars
where there from the previous runs, but I was no longer able to generate
the 1st scalebar and the legends. If anyone needs anymore info please let
me know. Thanks in advance for your help.
Matt
Content-Type: text/html; name="index.html"
Content-Disposition: attachment; filename="index.html"
<html>
<head>
<title>MapServer Itasca Application</title>
<DEFANGED_script language="javascript">
function submit_form() {
var template = document.demo.map_web_template.options[document.demo.map_web_template.selectedIndex].value;
if(template.indexOf("frame") != -1) document.demo.action = "frames.html";
if(template.indexOf("dhtml") != -1) document.demo.action = "frames_dhtml.html";
</DEFANGED_script>
</head>
<body bgcolor="#FFFFFF">
<center><h2>MapServer Itasca Application</h2></center>
<p><hr><p>
This demonstration application will take you through various levels of complexity. Starting with a basic application that
allows a user to pan/zoom and change layers we add:
<ul>
<li> dynamically configured scalebars
<li> javascript-based panning
<li> query results to a frame
<li> and finally, a DHTML rubber-band zoom/query capabilty
</ul>
The base data is the old-reliable Itasca dataset that we know and love...
<!-- EDIT THE FORM ACTION -->
<DEFANGED_form name="demo" method="GET" action="/cgi-bin/mapserv" onSubmit="submit_form()">
<DEFANGED_input type="hidden" name="layer" value="lakespy2">
<DEFANGED_input type="hidden" name="layer" value="dlgstln2">
<DEFANGED_input type="hidden" name="zoomsize" value=2>
<!-- EDIT THESE HIDDEN VARIABLES -->
<DEFANGED_input type="hidden" name="map" value="/var/www/html/itasca.map">
<DEFANGED_input type="hidden" name="program" value="/cgi-bin/mapserv">
<DEFANGED_input type="hidden" name="root" value="/mapserver_demos/workshop">
<DEFANGED_input type="hidden" name="map_web_imagepath" value="images/">
<DEFANGED_input type="hidden" name="map_web_imageurl" value="http://tornado/images/">
<DEFANGED_select name="map_web_template" size="1">
<DEFANGED_option value="itasca_basic.html"> Basic Application
<DEFANGED_option value="itasca_adds_scalebar.html"> -- Adds second scalebar
<DEFANGED_option value="itasca_adds_pan.html"> -- Adds pan controls
<DEFANGED_option value="itasca_adds_frames.html"> -- Adds frames
<DEFANGED_option value="itasca_adds_dhtml.html"> -- Adds dhtml rubber-band box
</DEFANGED_select>
<DEFANGED_input type="submit" value="Initialize"></center>
</DEFANGED_form>
<p><hr><p>
</body>
</html>
Content-Type: application/DEFANGED-523016; name="itasca_map.DEFANGED-523016"
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="itasca_map.DEFANGED-523016"
IwojIFN0YXJ0IG9mIG1hcCBmaWxlCiMKTUFQCiAgTkFNRSBJVEFTQ0EKICBTVEFUVVMgT04KICBT
SVpFIDYwMCA2MDAKICBFWFRFTlQgMzg4MTA3LjYzNDQwMDM3OSA1MjAzMTIwLjg4NDA1OTUyIDUw
MDg5Ni4zMzkwMTk4MzQgNTMxMDI0My4zMDYxMzg5NwogIFVOSVRTIE1FVEVSUwogIFNIQVBFUEFU
SCAiZGF0YSIKICBJTUFHRUNPTE9SIDI1NSAyNTUgMjU1CiAgVEVNUExBVEVQQVRURVJOICJpdGFz
Y2EiCgogIElNQUdFVFlQRSBQTkcKCiAgIwogICMgUHJvamVjdGlvbiBkZWZpbml0aW9uLCBjb25z
dWx0IHRoZSBQUk9KLjQgZG9jdW1lbnRhdGlvbiBmb3IgcGFyYW1ldGVyIGRpc2N1c3Npb24KICAj
CiAgIyBQUk9KRUNUSU9OCiAgIyAgICJwcm9qPXV0bSIKICAjICAgImVsbHBzPUdSUzgwIgogICMg
ICAiem9uZT0xNSIKICAjICAgIm5vcnRoIgogICMgICAibm9fZGVmcyIKICAjCiAgIyAgIE9SOiAK
ICAjCiAgIyAgICJpbml0PWVwc2c6MjY5MTUiCiAgIyBFTkQKCiAgIwogICMgU3RhcnQgb2Ygc3lt
Ym9sIGRlZmluaXRpb25zICh3ZSdyZSBvbmx5IHVzaW5nIGEgZmV3KQogICMKICBTWU1CT0wKICAg
IE5BTUUgJ2NpcmNsZScKICAgIFRZUEUgRUxMSVBTRQogICAgUE9JTlRTIDEgMSBFTkQKICAgIEZJ
TExFRCBUUlVFCiAgRU5ECgogIFNZTUJPTAogICAgTkFNRSAnc3RhcicKICAgIFRZUEUgVkVDVE9S
CiAgICBGSUxMRUQgVFJVRQogICAgUE9JTlRTCiAgICAgIDAgLjM3NQogICAgICAuMzUgLjM3NQog
ICAgICAuNSAwCiAgICAgIC42NSAuMzc1CiAgICAgIDEgLjM3NQogICAgICAuNzUgLjYyNQogICAg
ICAuODc1IDEKICAgICAgLjUgLjc1CiAgICAgIC4xMjUgMQogICAgICAuMjUgLjYyNQogICAgRU5E
CiAgRU5EIAoKICAjCiAgIyBTdGFydCBvZiB3ZWIgaW50ZXJmYWNlIGRlZmluaXRpb24gKGluY2x1
ZGluZyBXTVMgZW5hYmxpbmcgbWV0YWRhdGEpCiAgIwogIFdFQgogICAgSEVBREVSIHRlbXBsYXRl
cy9oZWFkZXIuaHRtbAogICAgVEVNUExBVEUgInNldCBpbiBpbmRleC5odG1sIgogICAgRk9PVEVS
IHRlbXBsYXRlcy9mb290ZXIuaHRtbCAgICAKICAgIE1JTlNDQUxFIDEwMDAKICAgIE1BWFNDQUxF
IDE1NTAwMDAKICAgIElNQUdFUEFUSCAic2V0IGluIGluZGV4Lmh0bWwiCiAgICBJTUFHRVVSTCAi
c2V0IGluIGluZGV4Lmh0bWwiCiAgICBNRVRBREFUQQogICAgICBXTVNfVElUTEUgIlVNTiBNYXBT
ZXJ2ZXIgSXRhc2NhIERlbW8iCiAgICAgIFdNU19BQlNUUkFDVCAiVGhpcyBpcyBhIFVNTiBNYXBT
ZXJ2ZXIgYXBwbGljYXRpb24gZm9yIEl0YXNjYSBDb3VudHkgbG9jYXRlZCBpbiBub3J0aCBjZW50
cmFsIE1pbm5lc290YS4iCiAgICAgIFdNU19BQ0NFU1NDT05TVFJBSU5UUyBub25lCgogICAgICAj
IGNoYW5nZSB0aGlzIHZhbHVlIHRvIG1hdGNoIHlvdXIgc2V0dXAKIyAgICAgIFdNU19PTkxJTkVS
RVNPVVJDRSAiaHR0cDovL2xvY2FsaG9zdC5sb2NhbGRvbWFpbi9tYXBzZXJ2ZXJfZGVtb3MvaXRh
c2NhL2luZGV4Lmh0bWwiCiAgICAgIFdNU19PTkxJTkVSRVNPVVJDRSAiaHR0cDovL3Rvcm5hZG8v
aW5kZXguaHRtbCIKCiAgICAgIFdNU19TUlMgIkVQU0c6MjY5MTUiCiAgICBFTkQKICBFTkQKCiAg
IwogICMgU3RhcnQgb2YgcmVmZXJlbmNlIG1hcAogICMKICBSRUZFUkVOQ0UKICAgIElNQUdFIGdy
YXBoaWNzL3JlZmVyZW5jZS5wbmcKICAgIEVYVEVOVCAzOTMyMzQuMzkzNzAxMjYzIDUyMDU0MDUu
MTY0NDA3MjIgNDk1NzY5LjU3OTcxODk0OSA1MzA3OTU5LjAyNTc5MTI3CiAgICBTSVpFIDEyMCAx
MjAKICAgIFNUQVRVUyBPTgogICAgTUlOQk9YU0laRSA1CiAgICBNQVhCT1hTSVpFIDEwMAogICAg
Q09MT1IgMjU1IDAgMAogICAgT1VUTElORUNPTE9SIDAgMCAwCiAgICBNQVJLRVJTSVpFIDgKICAg
IE1BUktFUiAnc3RhcicKICBFTkQKCiAgIwogICMgU3RhcnQgb2YgbGVnZW5kCiAgIwogIExFR0VO
RAogICAgS0VZU0laRSAxOCAxMgogICAgTEFCRUwKICAgICAgVFlQRSBCSVRNQVAKICAgICAgU0la
RSBNRURJVU0KICAgICAgQ09MT1IgMCAwIDg5CiAgICBFTkQKICAgIFNUQVRVUyBPTgogIEVORAoK
ICAjCiAgIyBTdGFydCBvZiBzY2FsZWJhcgogICMKICBTQ0FMRUJBUgogICAgSU1BR0VDT0xPUiAw
IDAgMAogICAgTEFCRUwKICAgICAgQ09MT1IgMjU1IDI1NSAyNTUKICAgICAgU0laRSBUSU5ZCiAg
ICBFTkQKICAgIFNUWUxFIDEKICAgIFNJWkUgMTAwIDIKICAgIENPTE9SIDI1NSAyNTUgMjU1CiAg
ICBVTklUUyBNSUxFUwogICAgSU5URVJWQUxTIDEKICAgIFRSQU5TUEFSRU5UIFRSVUUKICAgIFNU
QVRVUyBPTgogIEVORAogIAogICMKICAjIFN0YXJ0IG9mIGxheWVyIGRlZmluaXRpb25zCiAgIwog
IExBWUVSCiAgICBOQU1FIGRyZ3MKICAgIFRZUEUgUkFTVEVSCiAgICBTVEFUVVMgT0ZGCgogICAg
IyBPRkZTSVRFIDMxCiAgICBPRkZTSVRFIDI1MiAyNTIgMjUyCiAKICAgIENMQVNTCiAgICAgIE5B
TUUgJ0RpZ2l0YWwgUmFzdGVyIEdyYXBoaWMnCiAgICAgIEtFWUlNQUdFIGdyYXBoaWNzL2RyZ3Nf
a2V5aW1hZ2UucG5nCiAgICBFTkQKIAogICAgTUVUQURBVEEKICAgICAgV01TX1RJVExFICJVU0dT
IDE6MjUwLDAwMCBEaWdpdGFsIFJhc3RlciBHcmFwaGljIgogICAgICBXTVNfQUJTVFJBQ1QgIkhp
YmJpbmcgYW5kIEJlbWlkamkgcXVhZHJhbmdsZXMuIFNlZSBodHRwOi8vZGVsaS5kbnIuc3RhdGUu
bW4udXMvbWV0YWRhdGEvZnVsbC9kcmduY2ltMS5odG1sIGZvciBtb3JlIGluZm9ybWF0aW9uLiIK
ICAgICAgV01TX1NSUyAiRVBTRzoyNjkxNSIKICAgIEVORAogICAgVElMRUlOREVYIGRyZ2lkeAog
IEVORAoKICBMQVlFUgogICAgTkFNRSBjdHliZHB5MgogICAgVFlQRSBQT0xZR09OCiAgICBTVEFU
VVMgREVGQVVMVAogICAgREFUQSBjdHliZHB5MgoKICAgICMgbm8gbmVlZCBmb3IgYSBiYWNrZ3Jv
dW5kIElGIHRoZSBVU0dTIHF1YWRzIGFyZSBiZWluZyBkcmF3bgogICAgUkVRVUlSRVMgIiFbZHJn
c10iCgogICAgQ0xBU1NJVEVNICdjdHlfbmFtZScKICAgIENMQVNTCiAgICAgIEVYUFJFU1NJT04g
J0l0YXNjYScKICAgICAgU1RZTEUKICAgICAgICBPVVRMSU5FQ09MT1IgMTI4IDEyOCAxMjgKICAg
ICAgICBDT0xPUiAyMjUgMjI1IDE4NQogICAgICBFTkQKICAgIEVORAogICAgQ0xBU1MgIyBldmVy
eSBvdGhlciBjb3VudHkgaW4gdGhlIHN0YXRlCiAgICAgIEVYUFJFU1NJT04gLy4vIAogICAgICAg
U1RZTEUgCiAgICAgICAgT1VUTElORUNPTE9SIDEyOCAxMjggMTI4CiAgICAgICAgQ09MT1IgMjU1
IDI1NSAyNTUKICAgICAgRU5ECiAgICBFTkQKICAgIE1FVEFEQVRBCiAgICAgIFdNU19USVRMRSAi
Q291bnR5IEJvdW5kYXJ5IgogICAgICBXTVNfQUJTVFJBQ1QgIkl0YXNjYSBDb3VudHkgYm91bmRh
cnkgc2hhcGVmaWxlLiBTZWUgaHR0cDovL2RlbGkuZG5yLnN0YXRlLm1uLnVzL21ldGFkYXRhL2Z1
bGwvY3R5YmRuZTIuaHRtbCBmb3IgbW9yZSBpbmZvcm1hdGlvbi4iCiAgICAgIFdNU19TUlMgIkVQ
U0c6MjY5MTUiCiAgICBFTkQKICBFTkQKCiAgTEFZRVIKICAgIE5BTUUgbWNkOTBweTIKICAgIEdS
T1VQIGNpdGllcwogICAgVFlQRSBQT0xZR09OCiAgICBEQVRBIG1jZDkwcHkyCiAgICBTVEFUVVMg
T0ZGCiAgICBDTEFTU0lURU0gY2l0eV9uYW1lCQogICAgQ0xBU1MKICAgICAgTkFNRSAiQ2l0aWVz
ICYgVG93bnMiCiAgICAgIEVYUFJFU1NJT04gLy4vCiAgICAgIFNUWUxFIAogICAgICAgIENPTE9S
IDI1NSAyMjUgOTAKICAgICAgRU5ECiAgICAgIFRFTVBMQVRFICJ0ZW1wbGF0ZXMvbWNkOTBweTIu
aHRtbCIKICAgIEVORAoKICAgIEhFQURFUiAidGVtcGxhdGVzL21jZDkwcHkyX2hlYWRlci5odG1s
IgogICAgRk9PVEVSICJ0ZW1wbGF0ZXMvbWNkOTBweTJfZm9vdGVyLmh0bWwiCgogICAgRFVNUCBU
UlVFICMgYWxsb3cgR01MIGV4cG9ydAoKICAgIE1FVEFEQVRBCiAgICAgIFdNU19USVRMRSAiTWlu
b3IgQ2l2aWwgRGl2aXNpb25zIgogICAgICBXTVNfQUJTVFJBQ1QgIk1pbm9yIGNpdmlsIGRpdmlz
aW9ucyBmb3IgSXRhc2NhIENvdW50eSAoYm91bmRhcmllcyBvbmx5KS4iCiAgICAgIFdNU19TUlMg
IkVQU0c6MjY5MTUiCiAgICBFTkQKICBFTkQKCiAgTEFZRVIKICAgIE5BTUUgdHdwcmdweTMKICAg
IFRZUEUgUE9MWUdPTgogICAgREFUQSB0d3ByZ3B5MwogICAgU1RBVFVTIE9GRgogICAgQ0xBU1MK
ICAgICAgTkFNRSAnVG93bnNoaXBzJwogICAgICBTVFlMRQogICAgICAgIFNZTUJPTCAnY2lyY2xl
JwogICAgICAgIFNJWkUgMiAgICAgICAgCiAgICAgICAgT1VUTElORUNPTE9SIDE4MSAxODEgMTQ1
CiAgICAgIEVORAogICAgRU5ECiAgICBNRVRBREFUQQogICAgICBXTVNfVElUTEUgIlRvd25zaGlw
IEJvdW5kYXJpZXMiCiAgICAgIFdNU19BQlNUUkFDVCAiUHVsaWMgTGFuZCBTdXJ2ZXkgKFBMUykg
dG93bnNoaXAgYm91bmRhcmllcyBmb3IgSXRhc2NhIENvdW50eS4gU2VlIGh0dHA6Ly9kZWxpLmRu
ci5zdGF0ZS5tbi51cy9tZXRhZGF0YS9mdWxsL3R3cHJnbmUyLmh0bWwgZm9yIG1vcmUgaW5mb3Jt
YXRpb24uIgogICAgICBXTVNfU1JTICJFUFNHOjI2OTE1IgogICAgRU5ECiAgRU5ECgogIExBWUVS
CiAgICBOQU1FIGxha2VzcHkyCiAgICBUWVBFIFBPTFlHT04KICAgIFNUQVRVUyBPRkYKICAgIERB
VEEgbGFrZXNweTIKCiAgICBDTEFTUwogICAgICBOQU1FICdMYWtlcyAmIFJpdmVycycKICAgICAg
VEVNUExBVEUgInRlbXBsYXRlcy9sYWtlc3B5Mi5odG1sIgogICAgICBTVFlMRQogICAgICAgIENP
TE9SIDQ5IDExNyAxODUKICAgICAgRU5ECiAgICBFTkQKCiAgICBIRUFERVIgInRlbXBsYXRlcy9s
YWtlc3B5Ml9oZWFkZXIuaHRtbCIKICAgIEZPT1RFUiAidGVtcGxhdGVzL2xha2VzcHkyX2Zvb3Rl
ci5odG1sIgogICAgCiAgICBUT0xFUkFOQ0UgMwoKICAgIERVTVAgVFJVRSAjIGFsbG93IEdNTCBl
eHBvcnQKCiAgICBNRVRBREFUQQogICAgICBXTVNfVElUTEUgIkxha2VzIGFuZCBSaXZlcnMiCiAg
ICAgIFdNU19BQlNUUkFDVCAiRExHIGxha2UgYW5kIHJpdmVyIHBvbHlnb25zIGZvciBJdGFzY2Eg
Q291bnR5LiBTZWUgaHR0cDovL2RlbGkuZG5yLnN0YXRlLm1uLnVzL21ldGFkYXRhL2Z1bGwvZGxn
bGtweTIuaHRtbCBmb3IgbW9yZSBpbmZvcm1hdGlvbi4iCiAgICAgIFdNU19TUlMgIkVQU0c6MjY5
MTUiCiAgICBFTkQKICBFTkQgIyBsYWtlcwoKICBMQVlFUgogICAgTkFNRSBkbGdzdGxuMgogICAg
VFlQRSBMSU5FCiAgICBTVEFUVVMgT0ZGCiAgICBEQVRBIGRsZ3N0bG4yCgogICAgQ0xBU1MKICAg
ICAgTkFNRSAiU3RyZWFtcyIKICAgICAgVEVNUExBVEUgInRlbXBsYXRlcy9kbGdzdGxuMi5odG1s
IiAgICAgICAgCiAgICAgIFNUWUxFCiAgICAgICAgQ09MT1IgNDkgMTE3IDE4NQogICAgICBFTkQK
ICAgIEVORAoKICAgIEhFQURFUiAidGVtcGxhdGVzL2RsZ3N0bG4yX2hlYWRlci5odG1sIgogICAg
Rk9PVEVSICJ0ZW1wbGF0ZXMvZGxnc3RsbjJfZm9vdGVyLmh0bWwiCgogICAgVE9MRVJBTkNFIDUg
ICAgCgogICAgRFVNUCBUUlVFICMgYWxsb3cgR01MIGV4cG9ydAoKICAgIE1FVEFEQVRBCiAgICAg
IFdNU19USVRMRSAiU3RyZWFtcyIKICAgICAgV01TX0FCU1RSQUNUICJETEcgc3RyZWFtcyBmb3Ig
SXRhc2NhIENvdW50eS4gU2VlIGh0dHA6Ly9kZWxpLmRuci5zdGF0ZS5tbi51cy9tZXRhZGF0YS9m
dWxsL2RsZ3N0bG4yLmh0bWwgZm9yIG1vcmUgaW5mb3JtYXRpb24uIgogICAgICBXTVNfU1JTICJF
UFNHOjI2OTE1IgogICAgRU5ECiAgRU5EICMgc3RyZWFtcwoKICBMQVlFUgogICAgTkFNRSBjdHly
ZGxuMwogICAgR1JPVVAgcm9hZHMKICAgIE1BWFNDQUxFIDMwMDAwMAogICAgU1RBVFVTIE9GRgog
ICAgREFUQSBjdHlyZGxuMwogICAgVFlQRSBMSU5FCiAgICBDTEFTUwogICAgICBTVFlMRQogICAg
ICAgIENPTE9SIDAgMCAwCiAgICAgIEVORAogICAgRU5ECgogICAgTUVUQURBVEEKICAgICAgV01T
X1RJVExFICJDb3VudHkgUm9hZHMiCiAgICAgIFdNU19BQlNUUkFDVCAiQ291bnR5IHJvYWRzIChs
aW5lcyBvbmx5KS4gRGVyaXZlZCBmcm9tIE1ORE9UIHJvYWRzIGxheWVyLCBzZWUgaHR0cDovL2Rl
bGkuZG5yLnN0YXRlLm1uLnVzL21ldGFkYXRhL2Z1bGwvZG90cmRsbjIuaHRtbCBmb3IgbW9yZSBp
bmZvcm1hdGlvbi4iCiAgICAgIFdNU19TUlMgIkVQU0c6MjY5MTUiCiAgICBFTkQKICBFTkQgIyBj
b3VudHkgcm9hZHMKCiAgTEFZRVIKICAgIE5BTUUgY3R5cmRsbjNfYW5ubwogICAgR1JPVVAgcm9h
ZHMKICAgIE1BWFNDQUxFIDMwMDAwMAogICAgU1RBVFVTIE9GRgogICAgREFUQSBjdHlyZGxuMwog
ICAgVFlQRSBBTk5PVEFUSU9OCiAgICBMQUJFTElURU0gInJvYWRfbmFtZSIKICAgIENMQVNTCiAg
ICAgIFNUWUxFCiAgICAgICAgQ09MT1IgMjU1IDI1NSAyNTUKICAgICAgICBTWU1CT0wgJ3N5bWJv
bHMvY3R5aHd5LnBuZycKICAgICAgRU5ECiAgICAgIExBQkVMCiAgICAgICAgTUlORkVBVFVSRVNJ
WkUgNDAKICAgICAgICBNSU5ESVNUQU5DRSAxNTAKICAgICAgICBQT1NJVElPTiBDQwogICAgICAg
IFNJWkUgVElOWQogICAgICAgIENPTE9SIDAgMCAwCiAgICAgIEVORAogICAgRU5ECiAgICAgICAg
CiAgICBNRVRBREFUQQogICAgICBXTVNfVElUTEUgIkNvdW50eSBSb2FkcyIKICAgICAgV01TX0FC
U1RSQUNUICJDb3VudHkgcm9hZHMgKHNoaWVsZHMgb25seSkuIERlcml2ZWQgZnJvbSBNTkRPVCBy
b2FkcyBsYXllciwgc2VlIGh0dHA6Ly9kZWxpLmRuci5zdGF0ZS5tbi51cy9tZXRhZGF0YS9mdWxs
L2RvdHJkbG4yLmh0bWwgZm9yIG1vcmUgaW5mb3JtYXRpb24uIgogICAgICBXTVNfU1JTICJFUFNH
OjI2OTE1IgogICAgRU5ECiAgRU5EICMgY291bnR5IHJvYWQgYW5ub3RhdGlvbgoKICBMQVlFUgog
ICAgTkFNRSBtYWpyZGxuMwogICAgR1JPVVAgcm9hZHMKICAgIE1BWFNDQUxFIDYwMDAwMAogICAg
U1RBVFVTIE9GRgogICAgREFUQSBtYWpyZGxuMwogICAgVFlQRSBMSU5FCiAgICBDTEFTUwogICAg
ICBOQU1FICJSb2FkcyIKICAgICAgU1RZTEUKICAgICAgICBDT0xPUiAwIDAgMAogICAgICBFTkQK
ICAgIEVORAoKICAgIE1FVEFEQVRBCiAgICAgIFdNU19USVRMRSAiSGlnaHdheXMiCiAgICAgIFdN
U19BQlNUUkFDVCAiSGlnaHdheXMtIHN0YXRlLCBVUyBhbmQgaW50ZXJzdGF0ZSAobGluZXMgb25s
eSkuIERlcml2ZWQgZnJvbSBNTkRPVCByb2FkcyBsYXllciwgc2VlIGh0dHA6Ly9kZWxpLmRuci5z
dGF0ZS5tbi51cy9tZXRhZGF0YS9mdWxsL2RvdHJkbG4yLmh0bWwgZm9yIG1vcmUgaW5mb3JtYXRp
b24uIgogICAgICBXTVNfU1JTICJFUFNHOjI2OTE1IgogICAgRU5ECiAgRU5EICMgaGlnaHdheXMK
CiAgTEFZRVIKICAgIE5BTUUgbWFqcmRsbjNfYW5ubwogICAgR1JPVVAgcm9hZHMKICAgIE1BWFND
QUxFIDYwMDAwMAogICAgU1RBVFVTIE9GRgogICAgREFUQSBtYWpyZGxuMwogICAgVFlQRSBBTk5P
VEFUSU9OCiAgICBMQUJFTElURU0gInJvYWRfbnVtIiAgICAKICAgIENMQVNTSVRFTSAicm9hZF9j
bGFzcyIKICAgIENMQVNTCiAgICAgIEVYUFJFU1NJT04gIjMiCiAgICAgIFNUWUxFCiAgICAgICAg
Q09MT1IgMCAwIDAgIyBkdW1teSBjb2xvcgogICAgICAgIFNZTUJPTCAnc3ltYm9scy9zdGh3eS5w
bmcnCiAgICAgIEVORAogICAgICBMQUJFTAogICAgICAgIE1JTkZFQVRVUkVTSVpFIDUwCiAgICAg
ICAgTUlORElTVEFOQ0UgMTUwCiAgICAgICAgUE9TSVRJT04gQ0MKICAgICAgICBTSVpFIFRJTlkK
ICAgICAgICBDT0xPUiAwIDAgMAogICAgICBFTkQKICAgIEVORAogICAgQ0xBU1MKICAgICAgRVhQ
UkVTU0lPTiAiMiIgCiAgICAgIFNUWUxFCiAgICAgICAgQ09MT1IgMCAwIDAgIyBkdW1teSBjb2xv
cgogICAgICAgIFNZTUJPTCAnc3ltYm9scy91c2h3eS5wbmcnCiAgICAgIEVORAogICAgICBMQUJF
TAogICAgICAgIE1JTkZFQVRVUkVTSVpFIDUwCiAgICAgICAgTUlORElTVEFOQ0UgMTUwCiAgICAg
ICAgUE9TSVRJT04gQ0MKICAgICAgICBTSVpFIFRJTlkKICAgICAgICBDT0xPUiAwIDAgMAogICAg
ICBFTkQKICAgIEVORAogICAgQ0xBU1MKICAgICAgRVhQUkVTU0lPTiAiMSIgCiAgICAgIFNUWUxF
IAogICAgICAgIENPTE9SIDAgMCAwICMgZHVtbXkgY29sb3IKICAgICAgICBTWU1CT0wgJ3N5bWJv
bHMvaW50ZXJzdGF0ZS5wbmcnCiAgICAgIEVORAogICAgICBMQUJFTAogICAgICAgIE1JTkZFQVRV
UkVTSVpFIDUwCiAgICAgICAgTUlORElTVEFOQ0UgMTUwCiAgICAgICAgUE9TSVRJT04gQ0MKICAg
ICAgICBTSVpFIFRJTlkKICAgICAgICBDT0xPUiAyNTUgMjU1IDI1NQogICAgICBFTkQKICAgIEVO
RAoKICAgIE1FVEFEQVRBCiAgICAgIFdNU19USVRMRSAiSGlnaHdheXMiCiAgICAgIFdNU19BQlNU
UkFDVCAiSGlnaHdheXMtIHN0YXRlLCBVUyBhbmQgaW50ZXJzdGF0ZSAoc2hpZWxkcyBvbmx5KS4g
RGVyaXZlZCBmcm9tIE1ORE9UIHJvYWRzIGxheWVyLCBzZWUgaHR0cDovL2RlbGkuZG5yLnN0YXRl
Lm1uLnVzL21ldGFkYXRhL2Z1bGwvZG90cmRsbjIuaHRtbCBmb3IgbW9yZSBpbmZvcm1hdGlvbi4i
CiAgICAgIFdNU19TUlMgIkVQU0c6MjY5MTUiCiAgICBFTkQKICBFTkQgIyBoaWdod2F5IGFubm90
YXRpb24KCiAgTEFZRVIKICAgIE5BTUUgYWlycG9ydHMKICAgIFRZUEUgUE9JTlQKICAgIERBVEEg
YWlycG9ydHMKICAgIFNUQVRVUyBPRkYKICAgIENMQVNTCiAgICAgIE5BTUUgJ0FpcnBvcnRzJwog
ICAgICBTVFlMRQogICAgICAgIENPTE9SIDEyOCAyNTUgMTY0CiAgICAgICAgU1lNQk9MICdjaXJj
bGUnCiAgICAgICAgU0laRSA3CiAgICAgIEVORAogICAgICBURU1QTEFURSAidGVtcGxhdGVzL2Fp
cnBvcnRzLmh0bWwiCiAgICBFTkQKCiAgICBIRUFERVIgInRlbXBsYXRlcy9haXJwb3J0c19oZWFk
ZXIuaHRtbCIKICAgIEZPT1RFUiAidGVtcGxhdGVzL2FpcnBvcnRzX2Zvb3Rlci5odG1sIgoKICAg
IFRPTEVSQU5DRSA1CgogICAgTUVUQURBVEEKICAgICAgV01TX1RJVExFICJBaXJwb3J0cyIKICAg
ICAgV01TX0FCU1RSQUNUICJBaXJwb3J0IHJ1bndheXMgZm9yIEl0YXNjYSBDb3VudHkuIgogICAg
ICBXTVNfU1JTICJFUFNHOjI2OTE1IgogICAgRU5ECiAgRU5ECgogIExBWUVSCiAgICBOQU1FIG1j
ZDkwcHkyX2Fubm8KICAgIE5BTUUgY2l0aWVzCiAgICBUWVBFIEFOTk9UQVRJT04KICAgIERBVEEg
bWNkOTBweTIKICAgIFNUQVRVUyBPRkYKICAgIExBQkVMSVRFTSAiY2l0eV9uYW1lIgogICAgQ0xB
U1NJVEVNICJjaXR5X25hbWUiCiAgICBMQUJFTE1BWFNDQUxFIDUwMDAwMAogICAgQ0xBU1MKICAg
ICAgRVhQUkVTU0lPTiAvLi8gICAgICAKICAgICAgTEFCRUwKICAgICAgICBDT0xPUiAwIDAgMAog
ICAgICAgIFNIQURPV0NPTE9SIDIxOCAyMTggMjE4CiAgICAgICAgU0hBRE9XU0laRSAyIDIKICAg
ICAgICBUWVBFIEJJVE1BUAogICAgICAgIFNJWkUgTUVESVVNCiAgICAgICAgUE9TSVRJT04gQ0MK
ICAgICAgICBQQVJUSUFMUyBGQUxTRQogICAgICAgIEJVRkZFUiAyCiAgICAgIEVORAogICAgRU5E
CgogICAgTUVUQURBVEEKICAgICAgV01TX1RJVExFICJNaW5vciBDaXZpbCBEaXZpc2lvbnMiCiAg
ICAgIFdNU19BQlNUUkFDVCAiTWlub3IgY2l2aWwgZGl2aXNpb25zIGZvciBJdGFzY2EgQ291bnR5
IChhbm5vdGF0aW9uIG9ubHkpLiIKICAgICAgV01TX1NSUyAiRVBTRzoyNjkxNSIKICAgIEVORAog
IEVORAoKRU5EICMgTWFwIEZpbGUK
--MIMEStream=_0+165804_926459201569_788237211875--
