[Mapserver-users] Shapelib, GPC, PHP, and polygon clipping
Ryan, Adam
ARyan at co.linn.or.us
Fri Apr 30 20:38:04 EDT 2004
Steve, Frank, etc...
A while back Steve Lime wrote in response to a request for polygon clipping
code.
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0201/msg00094.html
He suggested using the GPC library. I checked this out and was able to get
it to work.
Is it worth trying to use GPC with either PHP mapscript or shapelib directly
and write a little routine to grab the shapes in question, convert them to
gpc ascii format, run the clip operation, and convert back to a shapefile
result? In PHP I could build the ASCII files, then call a gpc executable,
and then translate the ASCII result back into a new shapefile.
Am I exploring old technology? Is there a better way? Seems like a lot of
steps but all the really hard work has been done and it's just a matter of
reformatting data to work with the different tools.
I'd like to explore PostGis but we're a Windows shop and it's not in the
cards.
Thank you for any suggestions you might have,
Adam Ryan
GIS Analyst
Linn County GIS Department
Albany, OR 97321
aryan at co.linn.or.us
