Problems with select by Polygon
Randy Page
randy.page at TERRAVERGE.COM
Mon Aug 2 22:23:50 EDT 2004
Hi All,
Im attempting to select a group of census tracts using a user defined
polygon. As a test, I created a simple rectangle that I am using to
select the tracts. The end result I need is a list of the tract IDs that
fall within the supplied rectangle. Below is the URL I am using to
execute the query:
http://myserver.com/scripts/mapserv.exe?map=/maps/tiger.map&mapext=-
78.83+35.87+-
78.70+35.96&mode=nquery&mapsize=440+320&qlayer=tracts&layer=tracts&mapshape
=-78.83+35.96+-78.70+35.96+-78.83+35.87+-78.70+35.87+-78.83+35.96
Below is the layer definition from the mapfile:
LAYER
NAME "tracts"
STATUS DEFAULT
CONNECTIONTYPE postgis
CONNECTION "user=Administrator dbname=tiger
host=localhost"
DATA 'the_geom from tracts_c'
TYPE QUERY
TOLERANCE 5
CLASS
TEMPLATE querytemplate.html
END
END
I get two possible results:
1) If I include the TEMPLATE line, the server just sits there and
eventually times out.
2) If I comment out the TEMPLATE line, I get: msQueryByShape():
Search returned no results. No matching record(s) found.
Any ideas on what I am doing wrong?
Thanks in advance,
Randy
