"set in index.html" value
Marc-Andre Morin
ma_morin at SYMPATICO.CA
Tue Aug 3 09:49:51 EDT 2004
Steve,
I don't think that the problem is into my map file... I changed the
TEMPLATE paramater for the value "itasca_basic.html" and it works
properly...
So, probably you could find a solution into my index.html file or somewhere
else...
And for your info, I'm running Mapserver on Windows 2000 Pro.
MapServer version 4.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLI
ENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR
INPUT=GDAL I
NPUT=SHAPEFILE
HTP
Marc-Andre
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: August 2, 2004 12:15 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU; ma_morin at sympatico.ca
Subject: Re: [UMN_MAPSERVER-USERS] "set in index.html" value
How are you trying to launch the application? It might help to post that
page and the mapfile. I imagine it's something simple.
Steve
>>> ma_morin at sympatico.ca 07/31/04 12:54 PM >>>
All
I configured a map file according to my local data and I get the
following
error when I try to launch mapserver:
"Content-type: text/html msReturnPage(): Unable to access file. set in
index.html"
The "set in index.html" value is related to the TEMPLATE parameter of
the
WEB class into the map file...
Should I comment that line of change it for another?
Thanks in advance for your support.
regards,
Marc-Andre
