"set in index.html" value
Steve Lime steve.lime at DNR.STATE.MN.US
Tue Aug 3 08:13:43 PDT 2004
Know it's in the index.html. That file was set up to change templates
based on what demo was to be run. So a variable called
'map_web_template' was set and passed to MapServer. You removed that
part and hence the error. The easiest fix is to do exactly what you did
and add the template name into the map file. Alternatively set a hidden
variable called 'map_web_template' in your index.html file.
Steve
>>> ma_morin at sympatico.ca 8/3/2004 8:49:51 AM >>>
Steve,
I don't think that the problem is into my map file...  I changed the
TEMPLATE paramater for the value "itasca_basic.html" and it works
properly...
So, probably you could find a solution into my index.html file or
somewhere
else...
And for your info, I'm running Mapserver on Windows 2000 Pro.
MapServer version 4.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
 OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLI
ENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR
INPUT=GDAL I
NPUT=SHAPEFILE
HTP
Marc-Andre
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: August 2, 2004 12:15 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU; ma_morin at sympatico.ca
Subject: Re: [UMN_MAPSERVER-USERS] "set in index.html" value
How are you trying to launch the application? It might help to post
that
page and the mapfile. I imagine it's something simple.
Steve
>>> ma_morin at sympatico.ca 07/31/04 12:54 PM >>>
All
I configured a map file according to my local data and I get the
following
error when I try to launch mapserver:
"Content-type: text/html msReturnPage(): Unable to access file. set in
index.html"
The "set in index.html" value is related to the TEMPLATE parameter of
the
WEB class into the map file...
Should I comment that line of change it for another?
Thanks in advance for your support.
regards,
Marc-Andre
More information about the MapServer-users mailing list
