GDAL Results Interpret for Australian Raster
J. Delfos
jacob.delfos at MAUNSELL.COM
Wed Aug 4 20:15:13 EDT 2004
Those are pretty unusual bounding X coordinates. Where in Oz are you?
Check out this page:
http://mapserver.gis.umn.edu/doc40/raster-howto.html#formats
It has examples. I'd say your file is in UTM, but projected in the wrong
zone (2 zones too many to the east, or something). Your projection is
probably MGA, but possibly AMG. You better find out, because they differ
200m.
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Nick Dabner
Sent: 5 August 2004 07:12
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] GDAL Results Interpret for Australian Raster
Hello all,
I have a rasterset covering parts of Australia. TatukGis and other
products can view it, but I cannot even get it to simply display in
mapserver - usually just a blank screen. Furthermore, the information
provided by gdalinfo with respect to the datum is unknown, so I am not
sure if a projection is required etc.
Can anyone suggest the portions of the mapfile which would allow this
raster to load? I have included most of gdalinfo details below, TIA:
C:\gdal120\bin>gdalinfo.exe C:\ms4w\apps\MELWAY31\hgrtif\ADELBRIS.TIF
Driver: GTiff/GeoTIFF
Size is 4809, 4075
Coordinate System is:
PROJCS["unnamed",
GEOGCS["unnamed",
DATUM["unknown",
SPHEROID["unretrievable - using
WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT[,0.0174532925199433],
AUTHORITY["EPSG","0"]],
UNIT["unknown",1],
Origin = (1857716.251568,5544261.870844)
Pixel Size = (317.52333125,-317.52333125)
Metadata:
TIFFTAG_IMAGEDESCRIPTION=
TIFFTAG_DATETIME=2004:01:05 22:39:05
TIFFTAG_XRESOLUTION=300
TIFFTAG_YRESOLUTION=300
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Corner Coordinates:
Upper Left ( 1857716.252, 5544261.871)
(106439300d44'382252089395.85"E,31766280
5d42'1142461300788.73"N)
Lower Left ( 1857716.252, 4250354.296)
(106439300d44'382252089395.85"E,24352736
2d35'876173328429.93"N)
Upper Right ( 3384685.952, 5544261.871) (193928220d
0'700079669251.66"E,31766280
Lower Right ( 3384685.952, 4250354.296) (193928220d
0'700079669251.66"E,24352736
Center ( 2621201.102, 4897308.083)
(150183760d22'541165879323.76"E,28059508
4d 9'1009317314579.33"N)
Band 1 Block=4809x1 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 0,0,0,255
