GDAL Results Interpret for Australian Raster
Nick Dabner
dabner at OPTUSNET.COM.AU
Thu Aug 5 18:02:51 EDT 2004
Thanks Jacob.
As the path may have indicated. These are Ausways maps. I believe they
are in AMG66 format, although my associated vectors are in WGS84 so I
am told.
The map covers Adelaide to Brisbane which is potentially providing the
conflicting zone info you noted. I am personally in Melbourne.
How can you tell what zone - by the longitude? Would you use the
centroid as this is a large map?
regards, Nick
On 05/08/2004, at 10:15 AM, J. Delfos wrote:
> Those are pretty unusual bounding X coordinates. Where in Oz are you?
> Check out this page:
> http://mapserver.gis.umn.edu/doc40/raster-howto.html#formats
> It has examples. I'd say your file is in UTM, but projected in the
> wrong
> zone (2 zones too many to the east, or something). Your projection is
> probably MGA, but possibly AMG. You better find out, because they
> differ
> 200m.
> Jacob
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On
> Behalf Of Nick Dabner
> Sent: 5 August 2004 07:12
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] GDAL Results Interpret for Australian
> Raster
> Hello all,
> I have a rasterset covering parts of Australia. TatukGis and other
> products can view it, but I cannot even get it to simply display in
> mapserver - usually just a blank screen. Furthermore, the information
> provided by gdalinfo with respect to the datum is unknown, so I am not
> sure if a projection is required etc.
> Can anyone suggest the portions of the mapfile which would allow this
> raster to load? I have included most of gdalinfo details below, TIA:
> C:\gdal120\bin>gdalinfo.exe C:\ms4w\apps\MELWAY31\hgrtif\ADELBRIS.TIF
> Driver: GTiff/GeoTIFF
> Size is 4809, 4075
> Coordinate System is:
> PROJCS["unnamed",
> GEOGCS["unnamed",
> DATUM["unknown",
> SPHEROID["unretrievable - using
> WGS84",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT[,0.0174532925199433],
> AUTHORITY["EPSG","0"]],
> UNIT["unknown",1],
> Origin = (1857716.251568,5544261.870844)
> Pixel Size = (317.52333125,-317.52333125)
> Metadata:
> TIFFTAG_IMAGEDESCRIPTION=
> TIFFTAG_DATETIME=2004:01:05 22:39:05
> TIFFTAG_XRESOLUTION=300
> TIFFTAG_YRESOLUTION=300
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Corner Coordinates:
> Upper Left ( 1857716.252, 5544261.871)
> (106439300d44'382252089395.85"E,31766280
> 5d42'1142461300788.73"N)
> Lower Left ( 1857716.252, 4250354.296)
> (106439300d44'382252089395.85"E,24352736
> 2d35'876173328429.93"N)
> Upper Right ( 3384685.952, 5544261.871) (193928220d
> 0'700079669251.66"E,31766280
> Lower Right ( 3384685.952, 4250354.296) (193928220d
> 0'700079669251.66"E,24352736
> Center ( 2621201.102, 4897308.083)
> (150183760d22'541165879323.76"E,28059508
> 4d 9'1009317314579.33"N)
> Band 1 Block=4809x1 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
> 0: 0,0,0,255
