RV: [UMN_MAPSERVER-USERS] symbol question
Emil Zegers
EZS at DESTRAAT.NL
Thu Aug 5 08:39:56 EDT 2004
Hello Javier,
I've included an image to show how it looks on my machine.
I'm working with MapServer 4.2.
I don't know from what version up symbols with -99 -99 coding are supported but I suppose you have an older version?
Probably updating MapServer will fix it.
Here the layer definition I use with the "hek" symbol:
LAYER
NAME ACN
METADATA
"wms_title" "ACN"
END
PROJECTION
"init=epsg:28992"
END
TYPE POINT
STATUS ON
MAXSCALE 25000
DATA "acn"
CLASS
SIZE 8
SYMBOL "hek"
NAME 'ACN'
COLOR 255 0 0
END # CLASS
END # LAYER
Regards,
Emil Zegers
>>> Javier Castillejo Montes <jcastil1 at tragsa.es> 08/05/04 02:25pm >>>
-----Mensaje original-----
De: Javier Castillejo Montes
Enviado el: jueves, 05 de agosto de 2004 14:25
Para: 'UMN MapServer Users List'
Asunto: RE: [UMN_MAPSERVER-USERS] symbol question
Hi Emil
I tried your simbol, but how can i do to show one simbol after other, i
mean, instead on have the simbol X--X--X--X (more or less is the simbol,
isn't it? :-) What I get is in each piont of the line a simbols is drawn
so it does not appear as a simbol, just a line a bit bigger that if I don't
use the simbol
Below is the result i had!!
any ideas?
______________________________________________________
This message has been checked for all known viruses
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040805/e3d5fc78/mapserv.gif
