RV: [UMN_MAPSERVER-USERS] symbol question
Eduardo Spremolla
edspremolla at ANTEL.COM.UY
Thu Aug 5 08:51:55 EDT 2004
If I understand correct what he wants is to draw a line with the symbol.
In that case you have to use a overlay of 2 symbols.
Search the archive or the wiki for a railway lines examples.
LALO
El jue, 05-08-2004 a las 09:39, Emil Zegers escribió:
> Hello Javier,
> I've included an image to show how it looks on my machine.
> I'm working with MapServer 4.2.
> I don't know from what version up symbols with -99 -99 coding are supported but I suppose you have an older version?
> Probably updating MapServer will fix it.
> Here the layer definition I use with the "hek" symbol:
> LAYER
> NAME ACN
> METADATA
> "wms_title" "ACN"
> END
> PROJECTION
> "init=epsg:28992"
> END
> TYPE POINT
> STATUS ON
> MAXSCALE 25000
> DATA "acn"
> CLASS
> SIZE 8
> SYMBOL "hek"
> NAME 'ACN'
> COLOR 255 0 0
> END # CLASS
> END # LAYER
> Regards,
> Emil Zegers
> >>> Javier Castillejo Montes <jcastil1 at tragsa.es> 08/05/04 02:25pm >>>
> -----Mensaje original-----
> De: Javier Castillejo Montes
> Enviado el: jueves, 05 de agosto de 2004 14:25
> Para: 'UMN MapServer Users List'
> Asunto: RE: [UMN_MAPSERVER-USERS] symbol question
> Hi Emil
> I tried your simbol, but how can i do to show one simbol after other, i
> mean, instead on have the simbol X--X--X--X (more or less is the simbol,
> isn't it? :-) What I get is in each piont of the line a simbols is drawn
> so it does not appear as a simbol, just a line a bit bigger that if I don't
> use the simbol
> Below is the result i had!!
> any ideas?
> ______________________________________________________
> This message has been checked for all known viruses
Eduardo Spremolla <edspremolla at antel.com.uy>
Antel I+D
