symbol question
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Aug 5 09:07:02 EDT 2004
Hi Emil, Javier,
I also experience the same behaviour Javier describes, and I use Mapserver
4.2.1.
The difference is Emil uses a POINT layer, whereas I use a LINE layer and
Javier probably also.
Any ideas?
Best regards,
Bart
> Hello Javier,
> I've included an image to show how it looks on my machine.
> I'm working with MapServer 4.2.
> I don't know from what version up symbols with -99 -99 coding are
> supported but I suppose you have an older version?
> Probably updating MapServer will fix it.
> Here the layer definition I use with the "hek" symbol:
> LAYER
> NAME ACN
> METADATA
> "wms_title" "ACN"
> END
> PROJECTION
> "init=epsg:28992"
> END
> TYPE POINT
> STATUS ON
> MAXSCALE 25000
> DATA "acn"
> CLASS
> SIZE 8
> SYMBOL "hek"
> NAME 'ACN'
> COLOR 255 0
> END # CLASS
> END # LAYER
> Regards,
> Emil Zegers
>>>> Javier Castillejo Montes <jcastil1 at tragsa.es> 08/05/04 02:25pm >>>
> -----Mensaje original-----
> De: Javier Castillejo Montes
> Enviado el: jueves, 05 de agosto de 2004 14:25
> Para: 'UMN MapServer Users List'
> Asunto: RE: [UMN_MAPSERVER-USERS] symbol question
> Hi Emil
> I tried your simbol, but how can i do to show one simbol after other, i
> mean, instead on have the simbol X--X--X--X (more or less is the simbol,
> isn't it? :-) What I get is in each piont of the line a simbols is drawn
> so it does not appear as a simbol, just a line a bit bigger that if I
> don't
> use the simbol
> Below is the result i had!!
> any ideas?
> ______________________________________________________
> This message has been checked for all known viruses
