TTF label wrong
Zamil Murji
Zamil.Murji at DIVESTCO.COM
Fri Aug 6 15:27:39 EDT 2004
Sorry here are the images...
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Zamil Murji
Sent: Friday, August 06, 2004 1:16 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] TTF label wrong
Hello list,
I've got a weird problem. I have a layer that is labeled using a TTF. At small sizes, these labels come out sharp for
everything but diagonal lines. If I bump up the size of the label, then everything comes out black (just as expected).
I've attached two images, one is with the label set to size 10 and the other with the label set to size 20.
Ideally what I'd like is the diagonal lines to show up black instead of grey at size 10.
Here is my layer definition:
LAYER
NAME "wells"
TYPE ANNOTATION
STATUS off
MAXSCALE 800000
CONNECTIONTYPE postgis
CONNECTION "user=idc dbname=idc host=idcmap port=5432"
DATA "the_geom from (select oid, *, chr(glyph_index(plot_symbol)) as well_symbol from main_well2) as new_table"
CLASSITEM uwi
LABELITEM "well_symbol"
CLASS
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT wells
# ANTIALIAS true
FORCE on
SIZE 10
POSITION cc
MAXSIZE 10
MINSIZE 10
END
END
PROJECTION
"init=epsg:4269"
END
END
I'm using:
MapServer version 4.2-beta2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=GDAL
INPUT=SHAPEFILE
Thanks in advance,
Zamil
Type: image/bmp
Desc: blackwells.bmp
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040806/5631cd54/blackwells.bmp
Type: image/bmp
Desc: greywell.bmp
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040806/5631cd54/greywell.bmp
