Problem with python mapscript
Franco Brusatti
chinobrusatti at YAHOO.COM.AR
Fri Aug 6 16:44:32 EDT 2004
Hi list:
I have a problem with python mapscrip. I use
MapServer version 4.2.2 OUTPUT=PNG OUTPUT=WBMP
SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7
INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Python 2.3.4
to install i use this:
$> swig -python -modern -o mapscript_wrap.c
../mapscript.i
$> python setup.py build
$> su
$> python setup.py install
When run the test, obtain this:
$> python tests/testMapScript.py -v
ERROR: testDrawLargeJPEG
(__main__.DrawLargeJPEGTestCase)
File "tests/testMapScript.py", line 422, in
testDrawLargeJPEG
self.mapobj1.setImageType('JPEG')
File "build/lib.linux-i686-2.3/mapscript.py", line
1757, in setImageType
def setImageType(*args): return
_mapscript.mapObj_setImageType(*args)
MapServerError: setImageType(): General error message.
Unable to find
IMAGETYPE 'JPEG'.
ERROR: testConstructorUrlStream
(__main__.ImageObjTestCase)
File "tests/testMapScript.py", line 822, in
imgobj = mapscript.imageObj(0, 0, 'GD/JPEG', url)
1837, in __init__
_swig_setattr(self, imageObj, 'this',
_mapscript.new_imageObj(*args))
MapServerError: msLoadImageGDStream(): GD library
error. Unable to
initialize image
FAIL: numpoints is immutable, this should raise error
File "tests/testMapScript.py", line 690, in
testAlterNumPoints
self.assertRaises(AttributeError, setattr,
self.line, 'numpoints', 3)
File "/usr/lib/python2.3/unittest.py", line 295, in
failUnlessRaises
raise self.failureException, excName
AssertionError: AttributeError
FAIL: testRemoveOutputFormat may error without GDAL
File "tests/testMapScript.py", line 988, in
assert num == 6, num
AssertionError: 5
Ran 115 tests in 2.380s
FAILED (failures=2, errors=2)
I try use this with Zope (ZMapServer 0.7.5), this
problem is after two o free
request crash server Zope.
Any idea?
sorry for my bad english.
Chino
Prefiero morir de pie, antes que vivir una vida agachado.
Ernesto Che Guevara
Correo Yahoo! - 6 MB, tecnología antispam ¡gratis!
Suscribite ya http://correo.yahoo.com.ar/
