Labels DO NOT appear on ms_newPointObj()?
Ishrar Hussain
ishrarh at YAHOO.COM
Wed Aug 11 13:10:15 EDT 2004
I am using the code below to plot a dynamic point
using ms_newPointObj(). Though I have added the LABEL
object inside the CLASS object of the LAYER which
contains the point, the label does not appear at all.
Please go through the code, and let me know if it
needs any change for making the label appear. I'm also
not sure whether the parameter for the annotation
string in ms_newPointObj() will be the one holding the
LABEL of the point.
The code is as follows:
<?php
//....Part of my PHP Code
$oImage = $oMap->draw();
$myPoint = ms_newPointObj();
$myPoint->setXY(542800.6235, 626730.4673);
$myLayer = $oMap->getLayerByName("Points");
$myPoint->draw($oMap, $myLayer, $oImage, 0, "The LABEL
of This Point");
//....continues
# Part of my Map File
LAYER
NAME "Points"
STATUS DEFAULT
TYPE POINT
UNITS METERS
SIZEUNITS PIXELS
# LABELITEM "Labels" # <-- I'm not sure about
LABELITEM here
LABELMINSCALE 1e+04
LABELMAXSCALE 4300000
TOLERANCE 0
TOLERANCEUNITS PIXELS
CLASS
NAME "Vehicle Class"
LABEL
TYPE TRUETYPE
FONT "fritqat"
SIZE 7
MINSIZE 4
MAXSIZE 256
POSITION CC
OFFSET 0 0
ANGLE 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 102 51 51
OUTLINECOLOR 204 255 204
ANTIALIAS TRUE
PARTIALS FALSE
FORCE FALSE
END #LABEL
STYLE
SYMBOL 2
COLOR 171 60 219
SIZE 10
MINSIZE 1
MAXSIZE 100
END #STYLE
END #CLASS
END #LAYER
I hope this will be enough for you to understand the
problem. looking forward to your early response.
Thank you.
Regards,
Ishrar
--- Eric Bridger <eric at GOMOOS.ORG> wrote:
> On Sun, 2004-08-08 at 09:37, Ishrar Hussain wrote:
> > I need to dynamically add labels to the points,
> which I
> > plotted with ms_newPointObj() following the code
> by
> > Merlos (available at
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptAddPoint).
> > The annotation string, which I put in the draw()
> > function of PointObj, does not appear as Label of
> the point.
> > Please, also let me know, if I have to add
> anything to
> > my Map file for this, and if so, then how.
> You will need to add a LABEL section to your CLASS.
> E.g.
> LABEL
> COLOR 255 0 0
> SIZE TINY
> END
__________________________________
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
http://promotions.yahoo.com/new_mail
