Labels DO NOT appear on ms_newPointObj()?
Eric Bridger
eric at GOMOOS.ORG
Wed Aug 11 14:10:14 EDT 2004
I would try adding, after your $point->draw()
$oMap->drawLableCache($oImage);
Eric
On Wed, 2004-08-11 at 13:10, Ishrar Hussain wrote:
> I am using the code below to plot a dynamic point
> using ms_newPointObj(). Though I have added the LABEL
> object inside the CLASS object of the LAYER which
> contains the point, the label does not appear at all.
> Please go through the code, and let me know if it
> needs any change for making the label appear. I'm also
> not sure whether the parameter for the annotation
> string in ms_newPointObj() will be the one holding the
> LABEL of the point.
> The code is as follows:
> <?php
> //....Part of my PHP Code
> $oImage = $oMap->draw();
> $myPoint = ms_newPointObj();
> $myPoint->setXY(542800.6235, 626730.4673);
> $myLayer = $oMap->getLayerByName("Points");
> $myPoint->draw($oMap, $myLayer, $oImage, 0, "The LABEL
> of This Point");
> //....continues
> # Part of my Map File
> LAYER
> NAME "Points"
> STATUS DEFAULT
> TYPE POINT
> UNITS METERS
> SIZEUNITS PIXELS
> # LABELITEM "Labels" # <-- I'm not sure about
> LABELITEM here
> LABELMINSCALE 1e+04
> LABELMAXSCALE 4300000
> TOLERANCE 0
> TOLERANCEUNITS PIXELS
> CLASS
> NAME "Vehicle Class"
> LABEL
> TYPE TRUETYPE
> FONT "fritqat"
> SIZE 7
> MINSIZE 4
> MAXSIZE 256
> POSITION CC
> OFFSET 0 0
> ANGLE 0
> BUFFER 0
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 102 51 51
> OUTLINECOLOR 204 255 204
> ANTIALIAS TRUE
> PARTIALS FALSE
> FORCE FALSE
> END #LABEL
> STYLE
> SYMBOL 2
> COLOR 171 60 219
> SIZE 10
> MINSIZE 1
> MAXSIZE 100
> END #STYLE
> END #CLASS
> END #LAYER
> I hope this will be enough for you to understand the
> problem. looking forward to your early response.
> Thank you.
> Regards,
> Ishrar
> --- Eric Bridger <eric at GOMOOS.ORG> wrote:
> > On Sun, 2004-08-08 at 09:37, Ishrar Hussain wrote:
> > > I need to dynamically add labels to the points,
> > which I
> > > plotted with ms_newPointObj() following the code
> > by
> > > Merlos (available at
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptAddPoint).
> > > The annotation string, which I put in the draw()
> > > function of PointObj, does not appear as Label of
> > the point.
> > > Please, also let me know, if I have to add
> > anything to
> > > my Map file for this, and if so, then how.
> > You will need to add a LABEL section to your CLASS.
> > E.g.
> > LABEL
> > COLOR 255 0 0
> > SIZE TINY
> > END
