mapserver 4.2.2 compile problem on redhat as3
Aaron Steele
asteele at BERKELEY.EDU
Fri Aug 13 13:28:38 EDT 2004
i spoke too soon. : }
the compile bailed out:
-L/usr/local/pgsql/lib -lpq -lcurl -L/usr/kerberos/lib -lssl -lcrypto
-lgssapi_krb5 -lkrb5 -lcom_err -lk5crypto -lresolv -ldl -lz
-L/usr/kerberos/lib -lz -lssl -lcrypto -lssl -lcrypto -lgssapi_krb5
-lkrb5 -lcom_err -lk5crypto -lresolv -ldl -lz -lz -lm -lstdc++ -o
shp2img
/usr/local/gdal-1.2.1/libgdal.la: file not recognized: File format not
recognized
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
shp2img.o is in the mapserver directory where i'm compiling...
thanks,
aaron
> hi daryl,
> yes, that was the culprit. the following change to my configure
> invocation satisfied the compile:
> --with-postgis=/usr/local/pgsql/bin/pg_config
> thanks,
> aaron
> On Aug 13, 2004, at 12:41 AM, Daryl Herzmann wrote:
>> Hi Aaron,
>> On Fri, 13 Aug 2004, Aaron Steele wrote:
>>> dear readers,
>>> i'm running redhat enterprise as3 and cannot compile mapserver 4.2.2:
>>>> ./configure
>>> --with-wfs
>>> --with-wmsclient
>>> --with-wfsclient
>>> --with-proj=/usr/local/proj-4.4.8
>>> --with-gdal=/usr/local/gdal-1.2.1/apps/gdal-config
>>> --with-postgis=/usr/local/postgresql-7.4.3/contrib/postgis-0.8.2
>>> --with-ogr=/usr/local/gdal-1.2.1/apps/gdal-config
>> I am not sure that your --with-postgis is correct. I think it should
>> point to the location of pg_config, for example
>> --with-postgis=/usr/local/postgresql-7.4.3/bin/pg_config
>> If pg_config is not found, you wind up with a blank include in the
>> Makefile and hence this error
>> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT -DUSE_EPPL
>> -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR
>> -DUSE_WFS_LYR -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_WBMP -DUSE_GD_FT
>> -DGD_HAS_GDIMAGEGIFPTR -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS
>> -I/usr/local/include -I/usr/local/proj-4.4.8/src
>> -I/usr/local/gdal-1.2.1/port -I/usr/local/gdal-1.2.1/gcore
>> -I/usr/local/gdal-1.2.1/alg -I/usr/local/gdal-1.2.1/ogr
>> -I/usr/local/gdal-1.2.1/ogr/ogrsf_frmts -I maptemplate.c -o
>> maptemplate.o
>> gcc: no input files
>> make: *** [maptemplate.o] Error 1
>> Notice the blank after the last '-I'
>> HTH,
>> daryl
