Can't view Envi HDR file...
Frank Warmerdam
warmerdam at POBOX.COM
Fri Aug 13 15:21:20 EDT 2004
Eduardo Patto Kanegae wrote:
> Band 1 Block=8401x1 Type=Int16, ColorInterp=Undefined
> Description = Mosaic (Band 1)
> Using OpenEV 1.80 I got a view like shown at the 'dem-openev.png' attached.
> But using MapServer I got only an image like shown in
> 'dem-mapserver.png' attached.
> My mapfile is:
> MAP
> EXTENT -183604.500 -86401.500 -158401.500 -64798.500
> IMAGETYPE dem
> SIZE 736 632
> OUTPUTFORMAT
> NAME dem
> DRIVER "GD/PNG"
> IMAGEMODE RGB
> END
> LAYER # imagem
> NAME "imagem"
> TYPE RASTER
> DATA "C:\local\mapas\envi\MOSAICOHGT"
> END
> END
Eduardo,
The issue here is that it is 16 bit data. By default MapServer just reads
non-8bit data by setting all values greater than 255 to 255 and all values
less than 0 to 0. I think you will want auto-scaling.
Try adding the following line to your raster layer definition:
PROCESSING "SCALE=AUTO"
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
