Can't view Envi HDR file...
Eduardo Patto Kanegae
lists at WEBMAPIT.COM.BR
Thu Aug 12 14:53:04 EDT 2004
I'm trying to use MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
to display a raster layer based on a ENVI HDR file.
the 'gldainfo' result of this file is:
Driver: ENVI/ENVI .hdr Labelled
Size is 8401, 7201
Coordinate System is:
LOCAL_CS["Geographic Lat/Lon",
UNIT["Meter",1]]
Origin = (-183604.500000,-64798.500000)
Pixel Size = (3.00000000,-3.00000000)
Corner Coordinates:
Upper Left ( -183604.500, -64798.500)
Lower Left ( -183604.500, -86401.500)
Upper Right ( -158401.500, -64798.500)
Lower Right ( -158401.500, -86401.500)
Center ( -171003.000, -75600.000)
Band 1 Block=8401x1 Type=Int16, ColorInterp=Undefined
Description = Mosaic (Band 1)
Using OpenEV 1.80 I got a view like shown at the 'dem-openev.png' attached.
But using MapServer I got only an image like shown in
'dem-mapserver.png' attached.
My mapfile is:
MAP
EXTENT -183604.500 -86401.500 -158401.500 -64798.500
IMAGETYPE dem
SIZE 736 632
OUTPUTFORMAT
NAME dem
DRIVER "GD/PNG"
IMAGEMODE RGB
END
LAYER # imagem
NAME "imagem"
TYPE RASTER
DATA "C:\local\mapas\envi\MOSAICOHGT"
END
END
What is wrong?
What should I change to display in MapServer just like the way it
appears in OpenEV?
best regards.
http://www.webmapit.com.br
UIN: 303747254
Valinhos/SP/Brasil +55(19)3871-4875
Treinamento em UMN MapServer -
http://www.webmapit.eti.br/ptbr/?menuoption=mapserver
I Encontro Nacional de Usuários MapServer -
http://mapserver.cttmar.univali.br/encontro2004
Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
***Fim da Mensagem / End of Message ***
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040812/4b193aa8/dem-openev.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040812/4b193aa8/dem-mapserver.png
