[UMN_MAPSERVER-USERS] Partly solved Labels Problem
Skweda O'Bomsawin
sobomsawin at KASSINI.COM
Thu Aug 12 14:50:25 EDT 2004
Hi list!
I finally partly solved my label problem. Actually, I bypassed it by using
POSITION UR instead of UC. The upper center position seems to cause a
problem with a postgis line layer. The workaround is to use another
position like upper right which gives me satisfactory results.
Have a nice day!
Skweda
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Stephen Woodbridge
Envoyé : 11 août 2004 17:07
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] Labels Problem
Try removing the "POSITION UC"
-Steve
Skweda O'Bomsawin wrote:
> Hi list!
> I have a weird label problem with Mapserver. I try to display street
names
> with an angle set to auto. My map file looks like this:
> CLASS
> Name 'road_labels'
> LABEL
> TYPE TRUETYPE
> FONT "arial"
> SIZE 7
> MINSIZE 4
> MAXSIZE 256
> POSITION UC
> ANGLE AUTO
> BUFFER 2
> MINDISTANCE 150
> MINFEATURESIZE 20
> COLOR 100 50 0
> SHADOWCOLOR 0 0 0
> SHADOWSIZE 0 0
> PARTIALS FALSE
> END
> END # Class
> As you can see on the picture I have sent, I am unable to get the labels
> centered on the street lines. Some names are as far as 400m from the
center
> of the street and the translation seems to be always parallel to the
street
> line. I'm using Mapserver 4.0 with Postgis 0.7 on a Whitebox Linux with
gd
> 1.8.4-12 and freetype 2.1.4-4.
> Thanks!
> Skweda O'Bomsawin
> sobomsawin at kassini.com
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.735 / Virus Database: 489 - Release Date: 2004-08-06
Incoming mail is certified Virus Free.
