mapserver 4.2.2 compile problem on redhat as3
Daryl Herzmann
akrherz at IASTATE.EDU
Fri Aug 13 16:11:56 EDT 2004
howdy,
On Fri, 13 Aug 2004, Aaron Steele wrote:
> my gdal install procedure (if suspicious, what is a more appropriate
> location...):
> in /usr/local/gdal-1.2.1/
>> ./configure
>> make
>> make install
The make install then installed the libraries and what not in /usr/local
and not /usr/local/gdal-1.2.1 , so your mapserver flag should be
--with-gdal=/usr/local/bin/gdal-config
Does /usr/local/bin/gdal-config work? If so, what does this report?
/usr/local/bin/gdal-config --libs
daryl
* Daryl Herzmann (akrherz at iastate.edu)
* Program Assistant -- Iowa Environmental Mesonet
* http://mesonet.agron.iastate.edu
